It will only work with a low power CPU that idles well and you would still be able to kill it by OCing the cards.HAHA looking forward to hearing the results.
true story...
wol-va-FAIL searches CL for "5850", finds an ad 2 months old for a complete rig with two 5850s, wol-va-FAIL emails dude and asks how much for one of the 5850s in his rig, dude responds and says he's not selling just one, either take both for $220 () or none at all, wol-va-FAIL tells him this week he can only buy one (bills were paid leaving little disposable wol-va-income), if he can wait until next week wol-va-FAIL can snag both, he says okay and leaves wol-va-FAIL his phone #...
wol-va-FAIL calls a few days later because he has a friend that has agreed to float wol-va-FAIL the extra cash for the trade, in his retardery wol-va-FAIL has inadvertently reminded dude to REPOST his sale on CL...the cards are gone already...
FML...
wol-va-FAIL is now extremely wol-va-SAD and not wol-va-GH/s...
My 5830 does 280Mhash/s using -v -w256 at 950mhz
I wonder if a CX430 psu can handle 2 5830's going at full tilt
LOL we're about to find out.
14 in stock supposidly on this site
it should be ok, as when mining everything but the video cards is at idle. You wouldn't have much headroom though.
Yes the bitcoin market rebounded from yesterday. It goes up and down often as of late. I cashed out 500 bitcoins the other day at 27$ a bitcoin. I wake up the next morning to see the rate at 10$ something i was like YES! haha. I will be ordering some new hardware here soon.
4 pcs going full tilt 24/7, and a 5th computer (my main pc) going when not gaming or other things. 4-5750's 1-6870. I crank out about 14 coins a week. Will probably pick up 4 more 5750's put them in crossfire and pick up another 6870 and put it in crossfire.
who said mining wasn't profitable. My friends thought i was crazy until i showed them my bank statement.
My 5830 does 280Mhash/s using -v -w256 at 950mhz and stock 1.168V it also got over 300Mhash/s at 1030Mhz and stock volts but there was one crash after a while so I bumped it down for stability.
im using that i get 240
guiminer?
my 5830 is doing ~245 using guiminer
any certain flags and switch to something betteR?
on 7x64
will have my 5870 running today and 6950 next week
Check your actual memory speed in the graphs in Afterburner. I've found that trying to set the memory lower than 800 on my 6950 doesn't actually work and resets the memory speed to stock.
i meant that generally
i think its pretty average
but yes i should quote since the thread moves so fast lol
btw setting up namecoin is similar?
im thinking to use my i7 920 at 3.6 GHz for namecoin and 5870 for bitcoin
from what I hear namecoin is the better mining option right now as they can be traded for bitcoins, with the exchange rates it actually favors switching to namecoins, a friend of mine already has switched and found two namecoin blocks yesterday (100 namecoins) while hashing at 325MH/s (yes, the difficulty isn't as high at namecoin yet), which made him more than 1 BTC whereas he would've made about 0.5BTC bitcoin mining, I switched about 170 MH/s (my 4870/4890 crossfire rig) to his namecoin miner using the same poclbm miner I use for bitcoins, just adding his ip instead of Deepbit and using his user and pass...
Try using Phoenix 1.48 with the flags: -k poclbm VECTORS BFI_INT AGGRESSION=14 WORKSIZE=256. You'll also want to overclock the core as high as you can get it because every 20Mhz or so makes a noticeble difference in Mh/s.
could you help explain how you set up namecoin on w64?
Is there any gui for namecoins? I am trying the mining right now. I see how coins can be transferred but not sure how to tell what I have if/when I get a block
as for how, download the namecoind client,
http://dot-bit.org/files/namecoin_w32.zip
C:\Users\xxx\AppData\Roaming\Namecoin\bitcoin.conf
rpcuser=xxx
rpcpassword=xxx
rpcport=9332
start the client
then poclbm.exe -d0 --port=9332 --user=xxx --pass=xxx -v -w128 (or whatever)
a list of commands with namecoind help
can be run in a separate section for queries
Anyone notice the price hasnt fluctuated at all in the last hour or 2? Looks like no trades have been made. Is this common?
my 5870 is at 900 for core and it wont let me go higher?
Yeah I'm giving up on this.
damn lol--i get speculating could be worthwile now
for the namecoind.exe i get stuck after creating the conf file, it seems like starting namecoind.exe again just gives a blank either through terminal or the exe?
so let me get this straight
after creating bitcoin.conf
i start another instance of guiminer? since my first is with my 5870
then my second would be with the i7s instead?
i was thinking about joining a pool and need a namecoin address but i cant seem to get to that step?
so..... I am thinking it might be a better idea to hoard your namecoins. Right now the difficulty is real low, thus the 50 to 1 ratio. But that will increase, and eventually reach a parity with bitcoins. Then you might be looking at a 1 to 1 ratio. Considering all the resources being put into mining that day might be sooner than anyone expects.
