- Jun 18, 2004
I haven't sold any of my LTCs from mining, got around 700 stashed. Think I'll be making a nice profit when it hits gox![]()
Nice.
We LTC hoarders are in for an outstanding payday... soon.
Hey guys I have an interesting question. I want to use HD4000 as the main gfx processor for windows navigation while using the 7970s for mining. But when I boot up this way, the hardware monitoring, voltage control, etc aren't functioning in afterburner, even when I have it set as so. Is there a way to do this?
Im going to show the green around my gills on this one but I got to ask...
With respect to the Butterfly Labs 50 Bitcoin Miner...will it not mine for Litecoins?
I mean the name is sort of a misnomer to us noobs for it being multipurpose...
Thanks
Thanks
I'm mining on my main workstation and really don't see much of a difference in rates during normal use. Watching a video full screen knocks it down about 7% or so on the GPU that is driving that monitor. I guess what I'm trying to say is I think the benefits are pretty small even if you can get it working right.
Thanks
1) no, my understanding is that LTC are not supported
2) fuck knows if BFL will ever deliver, if they do you can bet they will be waaaaaay late and miss their power/performance envelope, buyer beware
No it won't, litecoins have additional requirements beyond what it takes to mine bitcoins. It is designed to make it less likely that an ASIC miner will be implemented anytime soon for Litecoin mining.
BFL products are ASICs which are incredibly powerful at doing one thing. BTC uses the SHA-256 algorithm for mining whereas LTC uses Scrypt. Scrypt is much more complex and requires the use of lots of vram, which is another key difference between the two. Because of this, LTC is considered ASIC resistant due to greater hardware requirements making them more expensive to develop and produce.
anybody with a 7870 Tahiti LE card care to share their bitcoin/litecoin hashrates stock & overclocked, via cgminer and what flags you're using?
i'll most likely be hashing with litecoin in mind, and the 7950 needs a .64 memory:gpu clock ratio to get the best hash rates, and 7970's need a .57 ratio
i'll probably start at .57 and move upwards until I get good results but if anyone here has any hard concrete results i'd love to hear them
edit: posted this in the other bitcoin thread in the AMD subforum as well
disable ULPS
didn't work
did you unlock afterburner in the cfg with the EULA?
Do you guys think this water chiller would cool 7 overclocked 7970s?
http://www.performance-pcs.com/cata...e=product_info&cPath=59_373&products_id=32957
didn't work
If you have no monitors plugged into the PCIe adapters with monitor plugged into the IGP, the PCIe cards will be disabled. You need a dummy plug or plug a monitor into the cards.
For those still looking to put together a rig, I highly recommend getting voltage unlocked cards like the Sapphire 7950 Dual Fan. Mine came stock at 925/1250/1250mv, I'm able to run them at 1000/1500/1050mv (600kH/s). Reducing the voltage saves me 70W per card, so with four cards at reduced voltage the power for the fourth card is free.
In case anyone needs something like this for their rigs, I just ordered 7 PCIe powered extensions from Cablesaurus.com. They accept BTC, LTC, or USD which is why I ordered from there. The site is a little fishy (limited products, half finished website), so ill let yall know if its a scam. I've found posts around the net of people ordering from him successfully but ill let ya know when/if I get them.
is it possible to reduce voltage when litecoin mining?
Here's our shipment. $21k in video cards. I shit you not.
Go big, or go home is our motto. 2 co-workers and I are building rigs.
I bought 18 of these bad boys and have an xfx 7950 and a powercolor 7870 Tahiti.
When I'm up and running, I expect to have 11000 kH/s at stock speeds. It will take some time to get them all tuned and oc'd. Hopefully I can get 13000 kH/s. Electricity for me is 0.068 kwh.
2 gpus in my comp, 2 in the wife's, and 16x in mining baskets is the plan. spread them around the house and open the windows.
Right now, I have 7100 kH/s with 13 gpus running@stock. basket1=3x gpus, basket2,3,4 = 2gpus each running. my comp=2, wifecomp=2
I've been having major issues getting 3x gpus running on these Biostar boards
I have some 1x to 16x adapters being delivered this week, which will help with troubleshooting and expanding to 4x gpus per basket. I have 4 laundry baskets with:
PCP&C 950w (83A @12v) (purchased for $120 each)
G1610 cpu (purchased for $44 each)
Biostar TZ77XE3 motherboards purchased for $100 each
3x msi 7950 (purchased for $300 each shipped)
3x pci-e 16x risers ($5 ea shipped approx from China). Hopefully they don't fry my boards.
8GB ram ($52)
old spare hard drive
Encore EN-UW1X45 wifi usb adapter ($10 ea)
The problem is, reaper will either crash or only run the 3rd gpu @ <10% capacity.
So right now I just have 3 gpus running on one biostar board, and a coworker the same.
If I move that hard drive with that working 3gpu hdd to another basket, it will mine 3gpus successfully. So I've isolated this being a software problem. in the reaper.conf, the device that fails or performs poorly is not consistent either. On one board, device 0 is the bad gpu, and on 2 others it's device 1.
We're using win7 currently, but will likely be switching to BAMT if we can't get this resolved.
For the person who fixes my problem in <48 hrs, 5 LTC your way. otherwise 3 LTC bounty for fixing this issue.
