Lorien
- Aug 19, 2004
Lorien. Trade you some bitcoin for one of those cards?
YGPM
I'd love to find a 2gb 6950 for a reasonable price. Damn. Craigslist in my area never has JACK.
Do you guys think it is worth it to start this like in a month or two? I havnt ever done it and i think it sounds neat your getting paid for like a folding thing. Although it seems like it has gone down hill so idk...
if you're wanting to make money, I suggest not.So since i dont have any extra parts laying around its not something i should look into?
Oh, so if I have sigs turned off it won't display mine either?Lorien's Calc (I don't see a sig link): http://www.kaptain.me/btc_calc.php
Yup, the savings from not having to use your furnace during the winter would need to be entered into the equation for those of us living in the northern states.I just can't wait till winter when I turn every piece of computer hardware I own into data pumping space heaters for both F@H and BtC's. Oh, and I have alot! (mostly just old junk...)
are there any tweaks to manage the CPU overhead...this is harshing my bigadv bonus
try running smp 7 on your bigadv clientare there any tweaks to manage the CPU overhead...this is harshing my bigadv bonus
This will hurt your bigadv times a bit, but they won't get completely screwed up like they can when the GPU and CPU are fighting each other.
hmmm, been reading a bit on smp 7, there seems to be some conflicting information out there. This may be a little OT but I think quite a few of us with AMD cards are folding on the CPU and mining on the GPUs.
I do have both miners set to affinity with the same core (0) but I'm not sure how to configure FAHControl to not use that core. Further, some say that bigadv will not fold on fewer than 8 cores. Others seem to suggest that you just will not be supplied bigadv units with fewer than 8, but once you have the unit onboard you can manually turn off a core to dedicate to GPU overhead. Still others say that this is skirting the rules of folding and there seems to be some controversy.
me confused, only have so much time to sift reams of forum posts
did you stop because of thisI stopped folding not long after the new client but iirc bigadv wont work with smp 7 and the new client. With the old clients it wasnt an issue.
And to the people who say it's skirting the rules so is using a quad core intel with HT. Honestly as long as the work is getting done right standford doesnt care.
did you stop because of thisthe new client isn't even necessary. using the old client you shouldnt have any issues as long as your pc is capable of running bigadv at all
I have been backreading these threads and I have to say;
Lorien is one patient individual.
You need 8 threads in the cpu, it doesn't necessarily mean you have to run all 8 of them at once.I do have both miners set to affinity with the same core (0) but I'm not sure how to configure FAHControl to not use that core. Further, some say that bigadv will not fold on fewer than 8 cores. Others seem to suggest that you just will not be supplied bigadv units with fewer than 8, but once you have the unit onboard you can manually turn off a core to dedicate to GPU overhead. Still others say that this is skirting the rules of folding and there seems to be some controversy.
Far from it. Like I've said to others, I'm just paying forward the help I got when I was a noob.[H]ard bitcoin guru
If it helps any, my two 6970s at 1GHz/340MHz with 1.25v only used 560-570w, and that would be a lot lower if you used air cooling and, say, a single core Sempron.Hmm, tempted to grab one or two of those 6970s that Lorien linked. I've got the slots and the power to support them in my existing system. I think my HX1000 Corsair could handle 3 of them if I wanted to get crazy-mode. I can only add 1 to my cart at a time. I can however get 1 of the COD edition OC cards as well as another Powercolor with 880Mhz core for $253.
