BIOS for DOS?
coder_t2
Hello. So I want to update my BIOS for my motherboard for memory compatibility issues, but latest one says OS: DOS. I have asus p5n-e sli as the signature states. I am figuring that the update is only reflected in DOS and wouldn't help any in windows. But I am just listing it in this forum to double check. Thanks.
Pretty much means you copy it to a DOS bootable floopy and exicute the program from inside DOS there.
The file should just be a binary file. You can probably use it to flash in Windows with the appropriate Asus utility. I flash my Asus boards in Windows regularly and have never had a problem.
Then what does it mean when it says that the DOS for the OS for the BIOS as opposed to ALL OS?
