The Motherboard BIOS must be able to boot to a USB bootable device. Not all core bios versions have USB as a bootable option. Double check your documentation if you are unsure if this option is supported.
Make the USB Flash key bootable. Insure that you have the command.com, IO.sys and MSDOS.sys files on the USB key so that it will be bootable.
Place the unzipped batch files (batch file, flash utility, bios file and .txt file) on the USB key.
Make sure that the USB Flash Key is at the top of the boot order in your bios so that when the motherboard is turned on it will immediately boot to the USB Flash Key and boot cleanly to an A: prompt.
Simply type in flash at the A: prompt and the rest will be handled by the batch file itself.
Clear the CMOS. Reboot system and the flashed version of the BIOS should now be present on your monitor.
thats the unzipped file what do i need to put on the usb drive to flash it ?
or not lol, so i made a boot usb drive with rufus and copied the bios files to it ok and not a problem i plug it in and reboot to bios and nothing is there bar the usb dvd drive and usb is set to first boot order.
i tried the usb stick in the mobo usb socket direct and unplugged the dvd drive and still nothing in bios but it does beep if i pull it out and remove it but it is not showing as a bootable device.
i used a sandisc usb 3 drive could this be the problem ? and this thing gets HOT!
