Makaveli4life420
- Dec 31, 2006
i just put together my new system and something really stupid happened......everything powers up but.........the graphics card doesnt give any signal to my monitor...........the fan on the graphics card works because its a aftermarket fan and custom put on the gpu...... so its always runnning but there is no way to tell if the GPU is running because nothin come up on the screen which is the sceptre 22 inch wide........now the monitor works on my other computer with DVI so it cant be the monitor........ cant be the cable either because it works also on the other computer......i am thinking its either my mobo or GPU...
i dont really know and i have tried different cables and all different combinations of how to hook this thing up........ i am clueless now................
has anyone else had this problem?????
and wat do people think i should do about this?
i already called cutomer service and my buddy is going to test the GPU on his computer to see if its the GPU........ but thats not till tommorow and if it does work then it is my mother board.......
any comments???
ALSO
for the blue leds on the case 830 stacker...coolmaster.......the cord is a 4 pin connector but the mother board only has 2 pins open for the case led connection.....so when i plug in the 4 pin .... nothin boots up..........so i can use the leds which pisses me off........
is there anything i can do about this?
is there any adapters that can help me with this?
any comments???
ALSO
