Dietsprite
- Sep 7, 2007
Hey there [H]ard Community! I have been a forgoer of this forum for a while. I like looking at the galleries and such, that kind of follower. I recently bought components to a new rig. They are as follows:
Q6600
4g kingston hyperX RAM
XFX 8800GTS 640mb
Seagate 320gb hdd
dvd/cd blah
Intel D975XBX2 Mobo
Cooler Master 830 Stacker
and Thermaltake toughpower 850watt
Now here is where it gets squirrelly. So I assemble my Pc, thinking I have everything connected right. I go to start it up. Turns on and then off in less than half a second, like a power surge. I checked connections and tried again. Same. I started taking components off, video card, ram, cd and finally hdd. Once the hdd was removed it started up. I grabbed an old hdd and slapped that bad boy in there, started reassembling, testing it every time I put in a new piece of hardware. Then I get to the Video card. Does the same thing. I get severely frustrated and go to sleep. The next day(today) I take it to my friends computer repair shop. They conclude the PSU is faulty. I say ok thanks. I burn to best buy and pick up an Antec truepower trio 650 watts. I get home and slap that in, same problem with a twist. NOW it will stay on with the new hdd in, but not the video card. I read a little more and I soon find out I did not plug in the 4 pin power connector to the left of the CPU. I plug that in, and still, I press the power button, it turns on then immediately turns off. I have the pci e cable attached to the video card, everything is plugged in correctly. I am stumped. Again, the problem is with all of the components in place, I press the power button, the machine turns on then immediately turns off like a power surge or a short. HALP!
thank you
Q6600
XFX 8800GTS 640mb
Seagate 320gb hdd
dvd/cd blah
Intel D975XBX2 Mobo
thank you
