avatar[djedi]
- Sep 8, 2004
My primary design revolves around games, games, and more games! wheee! I also use my main rig to stream downloaded content to my ps3. If I care tear myself away from entertainment, I'll also do some work from home (but it's not like Excel and Visio require a TONS of horsepower).
I'd like to spend between $1500-$2000 upfront, and then be willing to spend up to $1000more later for upgrades (i.e. water cool down the road, etc).
3) Where do you live?
Metro-Charlotte, NC
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
PSU, CPU, Motherboard, Ram, Video card(s), optical drive, ssd, Optional: more monitors, watercooling kit, new mouse, new ratpad, mechanical keyboard
I just picked up a refurbed HAF 932 case that was on sale, and I also have a nvidia GTX 260 core 216 (for potential use as a dedicated PhysX card? your thoughts?)
6) Will you be overclocking?
Yes. I'd like to hit the magic 4.0Ghz. Can I start with air cooling, and then maybe move to water cooling down the road? Or should I just do water from the start?
I have a 24" NEC 2490wuxi (the one with the polarizer), it runs 1920x1200. I'd like to get multiple monitors eventually but it doesn't have to be right now. I'd like the option to do NVsurround.
I plan on buying and building late september, early october... at that point can I wait another month for xmas sales? Any new vid card/cpu/mb updates due in the next couple months?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I'd like USB 3 and 6GB/s Sata, SLI or CF is desired. I'm a little anal about sound, so a good soundcard would be nice, but many onboard sound chips are "good enough" so I could live without discrete sound.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
I already have a legit copy of Win 7 Ultimate [edit: 64 bit version]
So as you can see, I'd like to build a pretty beefy machine. My main questions revolve around the timing of my purchase... I have no pressure to buy, but i'd really like to upgrade before 12/31/2010. So any sales or tech upgrades that happen in the remainder of this year are fair game. If there's nothing major on the horizon, I'll be fine with building in September/October.
My auxillary questions revolve around cramming in as many technical features as possible: SLI capable, USB 3, 6GB/s, NVSurround/Eyefinity, Good sound reproduction, is using my current GTX 260 as a dedicated PhysX card worth it? Should I water cool at the begining... or do it down the road?
I think the big problem will be picking a motherboard that has the features I want (all of them!) but doesn't screw up on having all the cards fit, or PCI bus bandwidth getting choked, or things like that. Your thoughts are greatly appreciated!!
Metro-Charlotte, NC
