Everything can be hunky-dory until resolution, applied effects like AA, high quality textures, etc. max out the on-board memory of your card. Then it has to move some data to system memory and your frame rate drops from 60 to 5.
I'm almost done with Oblivion, for example--I waited until I could buy it with the major expansion packs in a package for $20, I've learned over the years that such a day almost always comes around!
My 8800GT-512 had plenty of horsepower for this older game, but when I got done adding all the visual quality enhancements that are available online, I would run into situations where the framerate just tanked. I got a better card just so I could have more memory onboard. The extra raw power didn't hurt either, of course. Sudden framerate dives and hard lockup crashes disappeared.
Quick guide:
512MB is plenty on a card like a Geforce 8800GT/9600GT/GT 240 or a Radeon 4670/4770/5670
896MB/1GB is good for a card like a Geforce GTX 2xx card or a Radeon 4870/4890/5770/58x0
512MB is overkill for anything slower than a 9600GT or Radeon 4670
The one that almost got me banging my head on the keyboard was the guy that insistently says he's got an uber 1Gig video card so he should be running everything at max. When i finally got him to check. It was a pentium card. HE WAS BRAGGING ABOUT A 1GIG ONBOARD CHIP!!!
Ok, to make sure I understand the gist of this. For the lower end cards, extra memory is almost irrelevant; but, on the higher end cards, it makes sense to go to 1GB.
So, on crossfire/sli with medium range cards, 512MB should be fine, and anything above would be of a negligible benefit.
No, we are talking single cards. For Crossfire, the combined memory of the 2 cards is the memory of a single card so it'd be a total waste to crossfire with only 512MB since the processing power of crossfire would quickly outstrip the memory available, bottlenecking it's potential power.
I was comparing running either a 2 x Radeon HD 4850 in CrossFire, or a 2x Radeon HD 5770 in CrossFire. I can see where having extra memory could never hurt.
Any insights or opinions on what you guys would do?
From what I've read, I presume ATI has the upper hand over Nvidia, until Fermi is introduced.
