Hopefully they will be just as tasty as 8102s.
Hopefully they will be just as tasty as 8101s.
Fixed.
by kasson » Thu Feb 14, 2013 1:27 pm
We're releasing a new bigWU project to beta, 8103. This is essentially a clone of 8102 (based on what we're seeing in 8102, we've identified some more conditions to explore) and thus has identical points & deadlines.
The projects in our 810X series have to do with how influenza virus gets into cells. This is something we do a lot of work on, both because influenza is an important disease and because the process of cell entry by influenza virus is a model to study other viruses as well as things like nerve impulse transmission. Thus the most direct applications are to infectious disease, but we hope to address diseases such as Alzheimer's (where some of the drugs specifically target certain kinds of nerve impulse transmission). There has been a lot of exciting experimental work in this field to come out recently, and our experimental colleagues are encouraging us to do more simulations. Unfortunately, the simulations take time (and we need a lot of simulations). That's where you come in...thanks to the consistent help of bigWU donors over time, we are starting to see some interesting results. We're following those up and hope they pan out.
Thanks for testing!
^^ This. I've been at -bigbeta as well. No signs.
Hey! I was able to capture Bigfoot and a Chupacabra, yet I can't get me a 8103.![]()
I wonder if *ahem* I can find a way to get a streak of these going.
I just got one as well - looking at 11 minutes and change on 4x 6172 for ~450k ppd.
Dude!Wow...... wow. I found a quadracornOn the 6180SE rig, 10:15 TPF for about 530K.
Dude!
You need to OC those chips. I'm getting TPF of 9:51 now with the 6166HE rig.![]()
[root@ancalagon /]# clockspeed
Running, please wait...
Refclock: 222.014 MHz
Clockspeed: 2775.181 MHz
It is a Gi board and the 6180SE chips do not like it compared to the GL board they where in.
Code:[root@ancalagon /]# clockspeed Running, please wait... Refclock: 222.014 MHz Clockspeed: 2775.181 MHz
16,5 minutes TFP on dual E5-2660@2.3 GHz after 44% complete, around 260k PPD expected. In short, roughly same as 8102's...
Is there a reason you have turbo disabled?
Which run of the project are your folding guys ?
Mine is Run 1, I think I saw some Run 0 also on some HFM.net screen caps ?
Since all the - very few - 8102's I folded were labelled Run 0, I was wondering if more Run -> more WUs than 8102's -> more PPD goodness ?![]()
Project ID: 8103
Core: GRO-A5
Credit: 22607
Frames: 100
Path: \\x.x.x.x\fah\
Number of Frames Observed: 49
Min. Time / Frame : 00:12:01 - 416,999.9 PPD
Avg. Time / Frame : 00:12:25 - 397,012.7 PPD
Cur. Time / Frame : 00:12:36 - 388,783.3 PPD
R3F. Time / Frame : 00:12:33 - 390,728.7 PPD
All Time / Frame : 00:12:25 - 395,998.8 PPD
Eff. Time / Frame : 00:12:32 - 391,380.8 PPD
