- May 7, 2007
Can the BFGTech 7900GT OC run without the PCI-E auxilary power connector?
I haven't OCed it beyond the company's specs and it is not modded in any way.
I know that some PCI-E gfx cards can run without this plug, though they go into a low power mode until it can be connected (i.e. the FX3450). However, some can't and give off a loud noise (i.e. the 6800GS).
I don't want to find out for myself because my system doesn't have a PCI-E power connector and my molex to PCI-E power adapter is not at my current location. That and it is a PIA to take my case apart (you know what I am talking about with this case).
I've run this card in my current system (in my sig) before with the adapter successfully, so there is no problem with that.
Also, don't recommend I get another PSU. I know my current one sux the big one, but it is all I can fit in this case at the moment without modding it.
All thanx in advance. I appreciate everyone's help.
