turtletrax
- Dec 31, 2005
This is my first post but I have read these forums for years. I had read many BFG threads about their declining RMA support and acuracy, so I thought I should tell my story in the hopes that BFG will begin to take these stories seriously.
I had a BFG 7800 GTX OC die on me so I phoned to get an RMA (this was December 9th) and it was the most confusing and frustrating tech call I have ever made. My last name is huge and quite strange, but not so strange I would have to spell it about ten times (which I did, then the same for my address.
I live in Canada but their support line is for Noth America so I assumed they would have alittle knowledge about the Postal Code system in Canada. I was wrong. Also most Canadians pronounce the letter z as "zed" and elsewhere is "zee". This caused them to get my shipping adress wrong not once but twice delaying my return by over two weeks. Each time the address bounced, meant another hour or so on hold on their support line. The second time I thought maybe my address isnt supported so I offered an alternate and they said it would be fine. Turns out I was right. Gave them the alternate and all was well... Wrong!!!
Decide on the 30th I should phone to see where the package is and spend about my 7th hour on the phone and get though to track the package and the package is delivered to teh alternate addy. I go and pick it up and there are two shipping boxes (one inside the other). The one on the inside had the wrong name on it and my phone number, the other had my name and the wrong phone number. Strange I thought, then I open it to see the card and there is a GT OC staring at me!! I couldnt believe it!! Yet another 45 minutes on the phone and they are sending me a GTX but talk about making sure they make every mistake they can.
I will be going with an alternate vendor for my future purchases. I hope BFG can find a way to correct these problems plaguing thier RMA department as I loved the card I had, but the mistakes are to big to deny for me. The main reason I bought the BFG, and for substantially more I might add, was the stories of great support and lifetime warranty. A lifetime of bad warranty is the same as none at all in my opinion.
So that is my story. Not as bad as others, but a story non-the-less.
