BFG 7900GT Broke **Pics Inside**
JDM-Y0-
Okay, I sold a 7900GT and the package broke somthing off the card. Can this be solderd back on? Here are some pics of what fell off and where at.
Yes, easily. It is a capacitor. I see it all the time in my line of work, devices with leads like that break off due to vibration and shock. Reason being that the solder only bonds with the bottom half of the leads.
Way I normally keep this from happening, (I probally see it 20-30 times a week) is to violate the IPC standards, and overflow the ends with solder. (Cover the entire end of the lead with solder) This serves to hold the component on much better than just the flow underneath it.
I have had that happen, it was pretty hard to solder back on, mine was alot smaller and in a group of other caps.
Looking at the pics, I think it can be done. I had a smtd chip replaced on my mobo couple of years back. Compared to that, this one looks lot easier.
Just make sure you solder it back on the right way. Electrolytic capacitors are polarized and, if you solder it on the wrong way, it could actually burst and/or explode. :eek: It's a small one, so it wouldn't be too bad, but it would probably mess up the card.
Just make sure you solder it back on the right way. ALL capacitors are polarized and, if you solder it on the wrong way, it could actually burst and/or explode. :eek: It's a small one, so it wouldn't be too bad, but it would probably mess up the card.
Corrected
Yeah, not the flat ones :)
I could easily solder it back on there. And if you found someone with a hot air soldering system, they could do it for you really fast.
Corrected
All the Sprague orange drops in the tone stacks my '69 Fender Bassman head aren't polarized, but the filter caps (between the B+ and ground) are. You could put them any way you like. :) You only have to worry if there's any indication right on the cap that one lead is different than the other (a plus on one end, a minus on the other, or both).
First of all, those are not electrolytic capacitors. They are solid state.
Second of all, those capacitors appear to be polarized to me. The blue on the metal cap indicates the positive side.
They look like SMT caps to me, so I would find someone that has the proper equipment. You could look up a technical school in your area with an electronics program. Chances are they will have better soldering equipment and skills than you.
Yeah that's polarized... I've had to solder back on capacitors on MANY X800/850 cards... I see them fall off all the time.
I have a Hakko936 station... works great, and I use silver solder with it.
I'll be honest, my soldering skills are not professional, but definitely intermediate. Sometimes, even after soldering, the cap will fall off again from vibration. It's easy to solder it back on, but not as easy to ensure it will stay on for a long period of time. My advice to you is to not rush in soldering this back on. You want to make sure you get it right the very first time...
I just feel like the more and more you try, the worse of a bond it may be. If you do have to try more than once, make sure you clean the leads again... if you try too many times, dirt will somehow get stuck into your latest bond and weaken it... eventually it will crumble and fall off.
I try to use high heat on my iron when I do caps on video cards, but DO NOT KEEP IT ON TOO LONG, or you can fry something without knowing it. I set my iron to roughly 650-700F when I do this... mainly b/c it'll melt the solder quicker b/c a quick soldering job that is neat seems to be the best bond. If you have a lower temp, it takes longer to bond and for some reason I've had better bonds when I do the soldering faster.
Again, take your time... figure out how to do it before you try!!!! Be patient, and your card will be as good as new.
Worst case, you may be able to RMA... considering it wasn't entirely your fault that it fell off... or did you smash it into something... I wouldn't feel bad RMAing b/c the manufacturer will resolder it properly and resell as refurb.
use flux when you solder, it helps the solder flow
that's definitely an electrolytic cap
not only electrolytics are polarized, tantalums are polarized too
Off topic, but you need to straighten out those memory heatsinks while your at it.
