Porter_
- Sep 10, 2007
Ah, bummer.
False^I don't know how alot of you guys are testing your frames, but anyone running a fermi card with anything less than an i series chip while claiming to have high minimum frames makes no sense.
My rig runs the game at pretty much medium settings with aniso and aa set at 1 and I get down to the 20's on panama canal when theres smoke or a lot of action going on. My 24" runs at 1920x1200.
Maps with less foilage run great, but panama will show you your system sucks if you run fermi with a 2+ year older chip.
I am probably going to snag a sandy bridge in the next week or two to finally be able to play this game properly.
rofl, I try to stay away from anything AOL related, but WINAMP FTW!!! I use it because I can set it to use my onboard sound which is optical out going to a harmon kardon receiver. This way I can have music playing on surround sound and have my X-Fi card dedicated to in game sound Blends amazing with open ear HD595sI see the culprit. WINAMP!
lol yep, That remix by Stuart Price aka Thin White Duke is great! He is an awesome electronic musician, his remix Coldplay - Talk (Thin White Duke Remix) is pure audiophile eargasmic. Lately I've been listening to alot of music that has been electronically remixed or dubstep remixed depending on the song... pretty much anything with good SQ with a decent bass line for my Velodyne DD-15 Digital Drive Series 1250W Class D (3000W Peak) subwoofer under my PC desk and no I did not spend the $5699 msrp on it, got it free from a friend of the family The only negative thing about this setup is that at full tilt my mouse will jump a 1/4" off the mouse pad lol.You really listen to Coldplay while you play BC2?
Just the fact that you know the name of a Britney Spear's song scares me lolThis is why I box out w/ paint. Can't have you guys finding out I listen to Britney Spear's "Stronger" on repeat while gaming.
§·H·ï·Z·N·ï·L·T·ï;1036662266 said:False^
I rarely ever drop below 50fps in a full server no matter whats going on around me with my Q9650.
This is with with a gtx570 which is getting returned soon, the 5870 I tested gets an around 7-10 more fps in heavy action like this using the below settings.
GPU usage is around 50-75% peaks to 89% during large in your face explosions.
CPU usage is a constant 82%.
Full server Panama Canal
1600x1200
4xAA
16xAF
All HIGH settings
HBAO off
Yep I'm very pleased with the upgrade decisions that I made.Nice argument, but you also happen to own one of the most powerful c2q's which is comparable to an oc'd i5. You are a minority as far as the c2q chips go, and those with the entry to mid range c2d or c2q will not have optimal performance in game.
Also, if you were pushing a higher resolution, I'm sure your gpu would be taxed a bit more, and the usage would scale up. That data tells me your cpu is dealing more than your gpu at that resolution. I think your setup would really show it's stuff if you were running 1920 to 2560. You would probably have minimum frames in the 40's to low 50's.
Well...it thinks it's a 460 w/ its .912 VID...so...§·H·ï·Z·N·ï·L·T·ï;1036663936 said:How you liking the new 470 so far Jod?
A 3.6 Ghz Q9550 w/ an 850 Mhz 460 dipped into the 30's. An i5 760 @ stock speeds w/ the same 460 never went below 60. Yorkfield might be one of the better C2Q's, but as far as Nvidia and Fermi's concerned, it's garbage....own one of the most powerful c2q's which is comparable to an oc'd i5.
Played many a L4D session on that setup (E8400). Very cool, very quiet, very fast. I bet Crysis would have been pretty swift w/ reasonable settings too. Though, I'm still holding out for the GTX 990 4 GB and an i13 octa to play it properly.§·H·ï·Z·N·ï·L·T·ï;1036665445 said:...E8500@4ghz and a gtx260...
Prove it!!Once again, I don't have the GPU slowdowns that other people seem to have.
ROFL!!!Played many a L4D session on that setup (E8400). Very cool, very quiet, very fast. I bet Crysis would have been pretty swift w/ reasonable settings too. Though, I'm still holding out for the GTX 990 4 GB and an i13 octa to play it properly.
I remember going from a P35/88GTX to a 680i/SLI88GT for that game and it ran like crap...still bitter. Terrible, terrible board/chipset that was.§·H·ï·Z·N·ï·L·T·ï;1036666529 said:ROFL!!!
I finally got lucky and struck gold after a lame Q9550 (3.6Ghz), i5 760(18millionvolts), and GTX 460 (1.018 VID).my MSI 460GTX 1Gb runs .962 on Perf. Level 3.....
And even lower framerate.
interesting stuff guys, thanks.
I found out why my new 6950 was only giving me ~30 fps at 19x12; BC2 only maxes one CPU core! Found some others complaining about this too. Supposedly fixed in an early patch, but alt+tabing clearly showed otherwise on my system. Setting core affinity in task manager I got it to use 4 cores, and got around 55 FPS avg with 19x12, high settings 4xAA. Still seems a bit low though, as the 5850 above got around the same, or better with similar settings Perhaps time to consider unlocking the extra shaders, and OC-ing a bit..
Also annoying that I have to alt-tab and change core affinity every time I run the game! Have to investigate this a bit more, considering turning off Hyper threading and see.
Are you not running a fully-patched version of the game? You shouldn't have to change the core affinity manually What OS?
