BF3 - White Dots
Gday [H] readers,
Just wondering if anyone else is experiencing whites dots when in dark areas on the seams where textures meet, and has been able to address it?
The following is from a 360 but illustrates the issue perfectly/verbatim:
http://www.youtube.com/watch?v=C-LYdLQpyUw
Can be consistently reproduced coming up from the basement after cutting the wires to the card bomb at the start of the game.
-Tried with and without OC on the vidcard and proc.
-11.10 Catalyst installed.
Any suggestions for a fix are welcome as well and thanks!
Looks like slight misalignment/Z-fighting between polygons. Not sure, though. I wouldn't say it's an overheating problem unless the white dots were all over the screen.
I have seen weird white outlines around some objects when using MSAA before (in ArmA2 primarily). Maybe try disabling AA in the game and see if that helps?
