Does overclocking your CPU and GPU really help frame rates? I ran BF3 at stock with my system. Then I overclocked my CPU to 4.5 Ghz and my GPU to 840/1325 and to me I may have gained 5 frames. I was under the impression that I should get alot more than that....
I recommend that once you are in the server of your choice, you alt tab back and close your browser.
I'm on Chrome and after I did this, all my issues and chugging went away immediately. Hope this helps.
no point in overclocking your cpu since you gpu is by far the limitation here.Does overclocking your CPU and GPU really help frame rates? I ran BF3 at stock with my system. Then I overclocked my CPU to 4.5 Ghz and my GPU to 840/1325 and to me I may have gained 5 frames. I was under the impression that I should get alot more than that....
this is a gpu limited game though so overclocking the gpu should give more fps.If you search online for bf3 cpu/gpu benchmarks, you will find out that OC'ing does not increase fps at all.
I gained 9-15fps with my overclock in sig below.Does overclocking your CPU and GPU really help frame rates? I ran BF3 at stock with my system. Then I overclocked my CPU to 4.5 Ghz and my GPU to 840/1325 and to me I may have gained 5 frames. I was under the impression that I should get alot more than that....
have you ever done any research on HT? on an i7 its almost just as likely to do nothing or even hurt performance in games as it is to help it. in BF 3 even just two cores of an i7 are all that is needed so of course HT will do nothing at all even if it was perfectly designed.Not noticed stuttering.
Are people certain HT is the cause of it?
Don't frame rates drop by disabling it?
why on earth would you build/buy a modern pc with just 2gb of ram? if you do not close down every thing on your computer before gaming then you will certainly get some hitching in some modern games.Hey all. I'm trying to run BF3 smoothly on my 2nd rig. Experiencing choppy gameplay with all settings to medium
Intel G620
H67
2GB DDR3
ATI 5670, running official 10.9 drivers
Monitor resolution: 1440x900
I'm considering dropping a stick of 4GB RAM in there to make it 6GB total.
However, I realize that the CPU OR the GPU will likely end up as the bottleneck in this case.
Any settings tweaks or cheap purchases I can make to make BF3 run better?
Or is the PC hopeless and I should drop the idea completely? :O
your cpu is pretty slow but the game should be playable with it. in most cases your 5670 is a little slower than an 8800gt which is the minimum required just to play the game. you might want to try low settings at this point. tbh you really should have tried that before posting just to see how your pc handled it.
Yeah, this is a driver/game issue apparently. I'm using the latest from nvidia on my GTX570. So, definitely something with the game as it's happening to both sides.
have the 9 and 6 swap places and that might fix your problem.I'm seeing the short green flashes with my Radeon HD 9670. Obnoxious at times but usually infrequent.
have the 9 and 6 swap places and that might fix your problem.![]()
use 16x AF. unless you are using some entry level $40 card, that setting has not had an impact on performance in many many years.
and oh yeah are some stunning graphics. lol, and this is Ultra settings so it looks like some corners were cut here.
gif image hosting
Something is wrong with your install or PC, cars look nothing like that for me. Granted they don't look stunning either, but way better than that.
Does anyone else have their page file option turned off and experience any crashes? Sometimes the game will just lock up and I will have to open the task manager and BF3 is just unresponsive. I have my page file options turned off. I have 12 GB of RAM but have read that some programs require alittle virtual memory.
I have mine on but it's small, 1-2GB.
In case anyone is running a similar rig, here are my settings. The game looks AMAZING to me. I put everything at Medium because that is how the Beta was at, in the Beta High was really Medium and when i first played retail i was having trouble and the game looked a lot different for some reason.
Windows 7 PRO 64 bit
Intel Core i7-920 (stock speeds)
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 Memory
EVGA GeForce GTX 460 (Fermi) Superclocked EE
Nvidia GeForce 285.38 BF3 Drivers
OCZ Vertex II SSD
Samsung 245BW
I'm not sure if this is a hardware, software, or driver problem--I am seeing a lot of textures flashing, especially when I look through a sniper scope. It looks like I am seeing the destructible edges of a building flashing when the building/wall is still intact. All sorts of stuff just flashing on and off.
This sound familiar to anyone? Running 11.10 preview 3 on rig in sig. I was so paranoid of it I took the window off my 600tSE and put two more fans on there blowing on the GPU, but I don't think it is a hardware problem. I'll try to get a SS.
I trust all your drivers are completely up to date?
Maybe take a few settings from ultra down to high just for grins.
I've also turn post processing AA completely off in my game even though my hardware can handle it and things look sharper, cleaner, and flat out better to my eyes.
YMMV
Hey guys,
Finally I had a chance to try BF3 and played some SP last night. With 1080P vsync off, motion blur and MSAA at off (the rest ultra)
Im getting around 50-70FPS. From my understanding I might get 10-20FPS hit when I start playing real BF3 game (MP)
I really like how the game looks at the moment (even with MSAA off).
Are there any other settings I can tweak to maximize FPS (i.e. setting textures to HIGH) that would give me some some boost without losing PQ?
Im using AMD Beta 3 preview drivers see my specs for the rest.
Thanks so much
Hopefully the new drivers fix the flashing green screen issue, it's not a dealbreaker but sometimes it's very distracting
