So this is awesome news. Can you possibly check something for me? Run strike at karkand. With 64 players and keep your eye on fraps. See what your lowest fps is on that map. I'm in the high 20s. Basically I want to know what my gtx 460 is capable of before I upgrade. If going to am i5 2500k @ 4.2 ghz means my gtx 460 wont drop below 45 fps under any circumstance in bf3... I'm in.
Your probably going to see significant improvement, especially if you OC it.
*UPDATE* Yep....BF3 and Skyrim run like new games now, getting 80-100fps in ultra settings 1900x1200 with dips in the mid 60s sometimes 6950 1GB Crossfire. So far no stuttering at all. Very happy.
fixed that for youi wonder how six REAL cores and eight fake cores stack up to I5 and I7 @ 4.5GHz but with only 4 REAL cores and 4 Fake Cores (HT)
i would like to see this same test with 1100T @ 4.2GHz and same GHz for fx 8150
i wonder how six REAL cores and eight REAL cores stack up to I5 and I7 @ 4.5GHz but with only 4 REAL cores and 4 Fake Cores (HT)
compare that someone
thanks
I was in the same situation, coming from a Q9550 (and x48 chipset) with 2x5870 / 1920x1200, now on 2500k @ stock..
Quite the improvement, about 20-30% in speed and no stuttering at all, more min fps. I'm going to install my Zalman 9700led and OC as soon as my lga1155 retention bracket arrives.
anyone?
it can be ANY SIX CORE CPU as long as it is a "real physical cores" which would also include the cheaper 1055/1065/1090/1100 cpu's from amd
this test should be relatively easy since intel made ALOT of SIX CORE cpu's also
there should be quite a few (i think the real problem is probably the graphics card to NOT bottleneck the tests
best to see if 64 MP makes a diff in fps going from >4.2ghz 6 core to 4 core
we would like to know just like the ppl with 2 core to 4 core wanted to know
I think it is time for a new thread.
I used fraps to track my framerates for 10 minutes. (fraps is actually known to perform slightly worse than MSI Afterburner).
1080p all settings maxed, except I'm not using any of the in game AA. I inject SMAA Anti-Aliasing with sweetFX. It performs slightly worse than the in game "post" (which is some form of FXAA) but gives the same or better level of edge smoothing, and doesn't blur textures like FXAA. I'm also using SweetFX to run the color saturation booster and slightly boosting sharpness. I believe it uses videocard shading power to do that.
so in summary, since i'm using fraps, SMAA, and taking some shading power to boost color saturation and sharpness----my numbers should represent a worst case scenario for my system!
my system is the following:
AMD Phenom II X6 overclocked from 2.8 to 3.7 GHZ
8GB of DDR3 overclocked from 800mhz to 886
my mother board northbridge is overclocked from 2000mhz to 2658mhz. (known to boost AMD peformance).
HIS Radeon 7870 overclocked gpu core from 1000mhz to 1150. GPU memory overclocked to 1325mhz (think stock is 1200mhz). This is a modest overclock and means my 7870 does not approach 7950 performance.
here are the numbers:
The first set is from "sabalan pipeline", physically a smaller map
The second set is from "Operation Riverside", this is a larger map.
both maps had over 58 players at the time of testing. Again, the numbers were benched over a period of ten minutes.
I will post some benchmarks later, with the Notherbridge set to stock speed, to see how this affects BF3.
I may also disable two cores and see how that peforms!
I used fraps to track my frameratess. (fraps is actually known to perform slightly worse than MSI Afterburner).
