Yeah i just can't get the BF2 graphics to look right on my new LCD. I'm running 1280 X 1024 currently. How can i get the graphics to look as good/ better than they did on my regular screen on 1028 x 768?
At a higher resolution the graphics should look better. So your saying the graphics at 1024 x 768 look better than at 1280 x 1024? Thats odd, try messing with your bf2 video settings.
In terms of getting it to look better, i believe after you have every other setting for visual quality and have been able to apply them successfully to the game ( restarted etc. ) then you should add the switches. i dunno in my case bf2 is quirky about how it accepts the settings. but hope that helps
