Okay, so I have two PSUs that was killed by a GTX 770 when using 6-pin to 8-pin PCI-E adapters. Granted, both are just 500W with only one PCI-E 6-pin each and so when I was testing my PC consisted of an Asus X99 Deluxe/U3.1 and 5820K with an EVGA Classified GTX 770 4GB (which needs two 8-pin PCI-e plugs), I used one 6-pin to 8-pin adapter and the other 8-pin requirement, I used the 4-pin molex to 6-pin PCI-E, then connect the 6-pin to 8-pin adapter to that, so I finally had two 8-pin PCI-E wires set for my GTX 770.
On one test, I was just using AID64 and ran System Stability Test overnight. GPU option wasn't checked. The PC was dead in the morning. I was like, "Strange. Why did it turn itself off?" I tried to turn it on, nothing. I could still see that there is power coming because the "standby LED" is still lit. I unplugged the power cord from the PSU for 30 seconds. Plugged it back in and turn it on. It only flickered for about 1/4 of a second, then nothing afterward. I'd only get the flicker and nothing else, so I tried the second PSU the same way as described above. Remember, both of these PSUs only have one 6-pin PCI-E wire set.
This time, I tried running Furmark GPU Burn-in just for the sake of it. Within 15 seconds, I heard a pop plus saw a spark inside the PSU box. A little smoke rose and the usual strong circuit burn smell followed. That PSU is completely dead. Not a flicker at all like the first one. So, my finding? Don't ever use 6-pin to 8-pin adapters (or molex to 6-pin then to 8-pin) again, especially if your PSU is somewhat weak to start with.
After those two dead PSUs, I tried my 700W that has two 8-pin PCI-E plugs and ran Furmark again, works fine. No problem.
I think the GTX 770 may have drawn too much power and the two PSUs couldn't handle it or something, thus killing them in the process.
I may be completely wrong, so take the advice with lots of grains of salt.
