Best WIRELESS CARD/ADAPTER
trainwreck951
What's the best wireless card or adapter that I can use to pick up signal from a couple hundred feet away? What card/adapter can pick up the best signal?
Please let me know..
Old linksys router with linux os flashed into it's firmware...
I havent found one I "liked" yet and tried most major brands. However couple hundred feet should not be an issue normally. That said,
The included antennas are all crap, and putting two little antenna on is just double crap.
You will find, as with all radio frequecy devices, its the antenna.
Get any card you like then go here an get decent antenna.
http://www.tessco.com/yts/partner/manufacturer_list/vendors/terrawave/index.html
or better yet, make your own !! :cool:
http://www.turnpoint.net/wireless/cantennahowto.html
