dbwillis said:So is he getting a windows cant load error, or a dead hard drive error?
If its the windows error, you can try a BartPE CD (Bootable windows CD) or if its the dead drive problem, you can slave it in another machine and try getdatabck from runtime.org, they've saved my butt several times
assuming the Hard Drive isn't totally dead, I would get an external enclosure (like MrGreg said) or slave it on someones machine.MrGreg62 said:Pull the drive and put it in external enclosure then scan it with another machine.
