best way to format a external HDD?
chronic9
i have a usb drive that I am selling on ebay and would like to format it a few times with something like Dban or alike.... only problem is, DBan and Gdisk dont pick it up.... i guess since its a USB drive?
you could open the usb enclosure take out the drive, stick it inside your comp and then use dban :D
....... GREAT idea... except i don't want to void the warranty on the unit.
ya a sticker right over the screw that holds the case shut. i stated in the auction, "warranty has not been void, case has never been opened" otherwise I would of popped that case open a LONG time ago.
Well, you could always fill the drive up with a few movies or something, then delete them. (Can be the same movie, 50x if you want)
ya fill the drive with garbage using some kinda large file like a movie, dvd iso image of linux or something then use file shredder to wipe it clean. Not exactly dban but it should do the trick
XP has a command you can use to wipe a drive's unused space.
cipher /w:n
where n is the driver letter.
It zeroes the unused space first, then i think it does some patterns. I mainly use it for zeroing the unused space though. I think it works by allocating a file as large as possible, then writing stuff to it.
edit: ms has a short writeup here: http://support.microsoft.com/kb/814599
I know you have plenty of solutions already, but running some of those tools from BartPE or UBCD4Win would do the trick as well.
