"Best" way to flash BIOS?
Q-Ball
So I'm planning on doing a full driver upgrade this weekend (vid card and chipset drivers). I've been lagging, don't think I've updated any drivers in months :p. Anyway, I decided "why not the BIOS, too?" I've never updated the BIOS since I've had the board (on version 1002). I could use the ASUS tool in windows, or should I do it from a floppy? Or does it not really make a difference? I guess I'd like to take the road that is least likely to cause something to go wrong. Mobo is A8N-SLI Deluxe.
Thanks in advance.
First of all, if you are planning to upgrade the bios DON'T.
Unless you are having bios related problems or a new bios brings significant performance increase of has better options there is no need to upgrade bios.
Now if you are going to do it anyway, then IMO the best route is to use a floppy. I've had bad experiences using windows based bios updates (nothing fatal,but still). Most problems with windows bases bios update is that it may conflict with some programs or services running at the same time. Since I can't tell if it may conflict with any startup programs you may have I think its safer to go the floppy route.
I use a flash drive and man the bios is loaded so much faster saves me from worrying about having a power failure. seeing floppies were so slow it would increase the slim chance.
I usually don't believe in the motto "If it ain't broke, don't fix it" but in this case I will make an exception. If you really don't need to, don't do it or you might be kicking yourself.
Thanks for the feedback guys. I think I'll hold off till its absolutely necessary. I want to overclock at some point and my understanding is that the early BIOS revisions suck for that on this board.
Basically, to make a long A8N-SLI Deluxe story short, your BIOS version 1002 will support the Clawhammer, Winchester and Newcastle core CPUs. No need to update to a later BIOS version unless you're having problems. However, you will need to update to a later BIOS version if you're planning to upgrade your CPU to a Venice or San Diego core CPU or an X2 CPU.
{For the record, when I got the X2 3800+ and the A8N-SLI Deluxe, the BIOS version originally installed on my particular A8N-SLI Deluxe was 1011, which supported most of the Toledo-core X2 CPUs, but (strangely) not my 3800+ (which requires BIOS version 1013 or later). I immediately flashed it to BIOS version 1014 after putting my rig together.}
If you're running an X2, you'll want the latest beta bios (1015 maybe) since it fixes some of the Vcore issues in previous bioses. It worked for me. Here is a case where there is fix in the bios so it's worth the risk.
i've had a few problems after flashing nf4's with any type of windows flash tool. and the a8n-sli/sli deluxe seems to be the most affected.
i've built a number of the a8n-sli deluxe's and they do benifit from a bios flash as the early bioses for them were crap-
if you flash it with a windows tool--what happens is the bios just overwrites the old bios, the the mb will no longer hold the settings .
try here for more bios info
http://www.rhcf.com/
The Rebels Haven Computer Forum Main Page
Not running a X2 yet...but one of these days :)
Ok, that's what I'd thought. Although honestly, I've left the board at stock since I've had it and it's been solid. The real problems I'd heard about were extremely limited OC abilities with the early BIOS versions.
the best overclocks i've had were with beta 1008-003
i have a rev 1 a8n-sli deluxe . i'm running 1013f now.
bumped 3.0 a few times with a early winchester 3000 on air with bh5's and that 1003-08 beta
actually overclocked higher with the asus than the dfi lp-ultra d i'm running now. :eek:
