Wich0 said:Looking for a good video card for my gf's computer under $100 bux. Only for casual gaming (simcity 4, the sims). Also it has to be AGP..I was looking at the 9600xt but I was wondering how the new gen cards will do vs. this.
Malogato said:The 9600XT is a previous core clocked higher than it originally was released, while I am sure you can further overclock the 9600XT, .. it's baseline is higher than that of the x700.
(It's harder to get a 50% overclock out of a 500mhz part than it is to get a 50% overclock out of a 400mhz part)
dagon11985 said:I would shell out a bit more money and get a 6600 gt, if you can't do that, then settle for the x700.
I would assume used, or under some refurb/rebate?Just picked up a 256MB X700 Pro for $50. Can't beat that
aldy402 said:radeon 9800pro or 9800XT, best cards for the value. Well just hope they don't die on you.
needmorecarnitine said:I think they are both 110nm parts but the 9600xt uses low k and the x700s don't
that gpureview site you posted looks helpful
mbmadness said:I would go with a 6600 or a 9800 Pro. They both have eight pixelpipe gpus.
d4588 said:For a new card I'd say the Geforce 6600. If you don't mind used then I would recommend a made by ATI 9800 Pro over the vanilla 6600.
Hello, he needs AGP! Pretty sure the 6600 ddr2 is PCI-E.Lord_Exodia said:Don't get me wrong dude I'm not a Hardcore nvidia fan. the 6600 I'm talking about is a special one. It can overclock 2 6600GT speeds. It has DDR 2 instead of ddr like the regular 6600. It would Own and Pwn a 9800 Pro.
Nice.ClearM4 said:Hello, he needs AGP! Pretty sure the 6600 ddr2 is PCI-E.
A new 9800 pro at newegg.com is $104 + $3 shipping
http://www.newegg.com/Product/Product.asp?Item=N82E16814140058
