Best Video Card for GAMING (with i7-8700)
Discussion in 'Video Cards' started by vilhiem, Apr 14, 2018.
  1. vilhiem
    vilhiem [H]Lite
    119
    Aug 24, 2005
    What's the best video card for gaming?
    My latest configuration specs include:
    • Intel Core i7-8700K
    • CORSAIR DOMINATOR Platinum 32GB (2x16GB) DDR4 3200 (PC4-25600) (2x16)
    Chikia12187 likes this.
  2. wyqtor
    wyqtor Limp Gawd
    378
    Dec 30, 2011
    nVidia Titan V.
    {NG}Fidel, Aireoth, AlphaQup and 6 others like this.
  3. DTN107
    DTN107 [H]ardness Supreme
    4,686
    Jun 30, 2008
    nVidia FX 5900
    {NG}Fidel and Joseph F like this.
  4. deaedius
    deaedius Gawd
    930
    Jun 18, 2014
    GTX 1080ti but the 2000 series is right around the corner. Titan V would be next bet if you wanted to spend the money on it.
  5. vilhiem
    vilhiem [H]Lite
    119
    Aug 24, 2005
    LOL ... $3000 video card!!! The occasional smugness on these forums always cracks me up
    {NG}Fidel likes this.
  6. wyqtor
    wyqtor Limp Gawd
    378
    Dec 30, 2011
    Hey, cut it out! You asked for the best, and I told you!
    And no, sadly I can't afford it either.
    If you're in the same boat as I am, you're better off waiting for August and the launch of the new nVidia series. If you can't wait until then, a 1080 Ti is your best bet.
    vilhiem likes this.
  7. entropism
    entropism 2[H]4U
    3,594
    Dec 23, 2004
    Smugness? You asked for the "best". Technically, that IS the best. You didn't say "Best for My use" or "best for these games" or "Best for this budget". You said best.
  8. vilhiem
    vilhiem [H]Lite
    119
    Aug 24, 2005
    Sorry ... I say the 'smugness' half-jokingly. But seriously, I always assume the 'default' question is regarding 'reasonable' cost products for most people on this board. I did say for gaming ... so if I need to say price, let's say around $500-$800
  9. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    8,590
    Jun 13, 2003
    1080Ti --> done, or wait for next releases. If prices are too high, wait.
    Maddness likes this.
  10. Decibel
    Decibel 2[H]4U
    3,808
    Nov 10, 2000
    Only buy 16gb RAM (32 is excessive for gaming) and stretch that $800 and get the most inexpensive 1080ti you find in stock that is not PNY.
    What kind of monitor do you have or are you picking up?
  11. Zorachus
    Zorachus [H]ardForum Junkie
    8,632
    Dec 17, 2006
    I agree the best that's not crazy is the GTX 1080 Ti. Otherwise wait till the next gen cards are out in the Fall, the GTX 2080 series
  12. vilhiem
    vilhiem [H]Lite
    119
    Aug 24, 2005
    which brand of the 1080TI is the best at the lowest cost ...?
  13. _l_
    _l_ I Am A Cock
    1,171
    Nov 27, 2016
    the fastest you can afford. I had a 8700k setup back in January, used an EVGA GTX 1070 Ti Ultra Silent card and it really was, ummm, silent (takes up 2 1/2 slots though). Ran any game smoothly on max setting but when I cranked down some of the eye candy I can't really see while gaming (like Tess and occlusion, etc) I can run games smooth at 80+ fps @ 1080p using FX-6300 and GTX 970 and saved what, $1300 as well? You have to decide if having games load faster is worth an extra $1300 LOL
  14. intransit
    intransit n00b
    34
    Mar 8, 2005
    What's the best "reasonable," which I'd define as 75% of optimum. Meaning the most bang for your buck.
  15. NIZMOZ
    NIZMOZ [H]ard|Gawd
    1,587
    Oct 23, 2007
    Serious note...1080ti. Asus Strix OC. Highest Clock.
  16. thecold
    thecold Limp Gawd
    251
    Nov 12, 2017
    It really depends on your monitor.
    kirbyrj and Archaea like this.
  17. tom_ozahoski
    tom_ozahoski Limp Gawd
    210
    Feb 24, 2014
    ATI Radeon HD 4870 X2, 1 GB, PCI
  18. Jason Martin
    Jason Martin n00b
    3
    Apr 11, 2018
    I will go the middle ground here. Since you have not stated what resolution or frame rate you are targeting, I will assume you need a gaming card now, but would like to maximize your bang for the buck. I would recommend you pick up a 1050 ti at the best price you can find, and hold the rest in savings for the next generation coming out this summer. The 1050 ti is a workable 1080p card if you are willing to relax the settings, and I think that it could be easily resold for a fair price, and you can then invest in a card that will last until the next major release a couple of years down the road (if not longer).
    craigdt likes this.
  19. vick1000
    vick1000 [H]ard|Gawd
    1,912
    Sep 15, 2007
    You list the top CPU, and complain when someone lists the top GPU?
    Me thinks you are just trying to get attention for your new rig: "look everybody, I gots a new shiny 8700".
    Reasonable is different for everyone, so you need to list a budget at least.
    defaultluser likes this.
  20. NIZMOZ
    NIZMOZ [H]ard|Gawd
    1,587
    Oct 23, 2007
    Listing a card that costs $3k that isn't even available yet, is not helping the guy. What currently is out, and the best card would be the 1080ti.
    vilhiem likes this.
  21. Decibel
    Decibel 2[H]4U
    3,808
    Nov 10, 2000
    Titan V is out, and in stock:
    https://www.nvidia.com/en-us/titan/titan-v/#shop
    Aireoth and defaultluser like this.
  22. Mega6
    Mega6 [H]ard|Gawd
    1,438
    Aug 13, 2017
    the Titan V is out. 3k. Last time I spent 3k for fun was suspension, fuel system, beefed up trans and a port on my supercharger for my car.
  23. Swift_OwL
    Swift_OwL Limp Gawd
    230
    Jan 8, 2008
    Last time i paid 3k was for a 2003 350z with 120k on clock. Will never pay that much for a graphics card. Honestly, my 290x which was released in 2014 can run most games max at 1080p.
    I can only imagine a 1060 gtx can run all games at max 1080p. That card is only 250. If your trying to game higher resolutions, then your looking at the mid to high range cards.
    Just purchased a 1080ti off the for sale forum, to start max setting gaming at 4k. Been gaming at 4k with none max settings for years with my 2x 290x.
    Wasn't going to pay 700+ for a 1080ti, but i told myself how long can i keep these 290x, haha paid 600 for the both of them 4 years ago, whats another 100 dollars to keep a 1080ti for 4 years.
  24. NukeDukem
    NukeDukem 2[H]4U
    2,250
    Feb 15, 2011
    1. Titan V
    2. Titan Xp
    3. GTX 1080 Ti
    These are your choices, otherwise wait until July for the 1100 series.
  25. Dayaks
    Dayaks [H]ardness Supreme
    6,658
    Feb 22, 2012
    Which monitor do you use and do you ever plan to use VR?
  26. vilhiem
    vilhiem [H]Lite
    119
    Aug 24, 2005
    I need a new monitor too ... would like a 4K display ... but also looking into those large wrap-around screens. Again ... as for price ... under $1,000 for sure.
    Thanks for understanding NIZMOZ
    NIZMOZ likes this.
  27. defaultluser
    defaultluser I B Smart
    12,147
    Jan 14, 2006
    If you don't give us any insight into what you want, you give the responders free reign to post whatever the fuck.
    Your processor is the best for every game in existence, so obviously a $3000 video card would not be be processor-limited.
    We can't make any assumptions if you don't provide:
    (1) game list
    (2) desired resolution
    (3) desired frame rates
    For all we know you're a 1080p 60Hz gamer who only plays Rocket League. Enjoy your GT 1030 :D
    See how assumptions are a waste everyone's time? If you had actually posted your desires, I would have given you a straight answer by now.
    Many types of games (MMOs, racing games, flight sims) are more processor-limited than GPU-limited, so you can also cheap-out on those. If you tend to stick to one genre of game, that can reduce the hit on your wallet as well.
    All you have to do is open the channel of communication with us, like you should have done in four first post.
    Archaea and AlphaQup like this.
  28. hlfbkd420
    hlfbkd420 Limp Gawd
    275
    Jun 16, 2017
    That's about all I play.... In 4K on an i5 760 (10yr's old) and a GTX 1070. Works like a champ with everything cranked at about 70-90 FPS...
    /Highjack
  29. defaultluser
    12,147
    Jan 14, 2006
    Exactly my point. We don't know what the fuck vilhiem plays or what resolution, and until then he's going to get shit for an answer.
    Even more casual games (DOTA 2 Reborn) could get by with a GTX 1060 6GB at 4k (with room to grow). While more demanding titles require a UP TO GTX 1080 Ti OR MORE. That's a huge fucking performance window!
    https://www.notebookcheck.net/Dota-2-Reborn-Notebook-and-Desktop-Benchmarks.194972.0.html
  30. rgMekanic
    rgMekanic [H]ard|News Staff Member
    3,759
    May 13, 2013
    Don't forget what site you're on. We SLI 1080s to play Minesweeper.
    https://hardforum.com/threads/prototype-4x-titan-v.1950322/
  31. Tweak155
    Tweak155 Gawd
    542
    Jul 28, 2011
  32. AlphaQup
    AlphaQup Limp Gawd
    265
    Oct 27, 2014
    OP, it wouldn't be a bad idea to put all the relevant info in your initial post (edit it to include resolution, refresh rate, etc. need the maximum eye candy? budget? games played, etc.) so we don't have to go through the thread and piece it together (might cut down on the lul replies too.)
    I do agree that you don't need 32GB of DDR4 strictly for gaming, that money could be spent elsewhere, and who knows, pick up another 16GB kit when DDR4 isn't stupid expensive.
    Also, if you have a proposed build, I'd post up the rig's specs. No mention of the case/PS etc. either. Some of those cards have MASSIVE coolers on them and might not fit your unknown to me case (I'm getting by with 2-3mm on the end of my 1080 in my Cosmos SE, it was a TIGHT fit.)
    Effort on your part = quality recommendations on our end, give us all the info you can and we'd be more then happy to chime in.
  33. _l_
    _l_ I Am A Cock
    1,171
    Nov 27, 2016
    what do you mean by "The Best" ?
    Buy the fastest card you can afford and be sure to buy EVGA if you want a warranty that actually exists. They have free 24/7 phone tech support (average wait time for me has been about 4 minutes per call). No other company comes close, most will send back your broken card and forget about reaching their warranty department by phone or email (which they never seem to respond too for some strange reason or other - like increased profit at your expense?)
  34. Shadowed
    Shadowed Limp Gawd
    468
    Mar 21, 2018
    Are you an EVGA rep? :p
    CAD4466HK and DF-1 like this.
  35. Algrim
    Algrim [H]ard|Gawd
    1,358
    Jun 1, 2016
    EVGA has a good reputation for honoring their warranty. In my view, it's concerning that it happens often enough that you end up needing that warranty. :eek:
  36. _l_
    _l_ I Am A Cock
    1,171
    Nov 27, 2016
    no, I no longer work in the tech industry (not for the past 25 years). Just personal experience with EVGA. The fact that I can call them 24/7 and reach a tech in short order blows all other companies out of the water (I email/call MSI, Gigabyte and ASUS numerous times in the past - never got an email reply and never reached a human on the phone).
    EVGA often wins PC industry Customer Service awards and for good reason
  37. AIM9x
    AIM9x [H]Lite
    65
    Feb 8, 2011
  38. Archaea
    Archaea [H]ardForum Junkie
    9,033
    Oct 19, 2004
    CPU doesn't really matter much at all in the context of your question -- you could go all the way back to Intel Sandy Bridge and it'd be the same recommendation to follow - it's the video card that matters for gaming --- and as to what video card you need - that depends on what monitor resolution you are gaming at.
    My general recommendation would be as follows:
    970, or 1060 6GB for 1080p resolution at 60hz - $200-$250
    or
    RX570 or RX580
    980TI, 1070, 1070TI, or 1080 for 1440p resolution - $350-$600
    or
    Fury X, Vega 56
    1080TI for 4K resolution - $700- $800
    or
    Vega 64
    There is never much reason to buy the Titan cards, unless you have unlimited funds. They have a "stupid tax" assigned. The general reality is you get 5% more performance for 50% more cost, and they will be outdated in the same timeframe as the top general consumer card (ie 1080TI) of that particular cycle. So the extra 50% cost isn't buying you anything long term either.
    If you have a high refresh rate monitor you might consider grabbing a card from the next higher tier - unless you use adaptive synch like Gsync or Freesync at which point your game will be smooth enough that's unnecessary.
  39. Mega6
    Mega6 [H]ard|Gawd
    1,438
    Aug 13, 2017
    Oh wait, I hear Nvidia has.. oh never mind.
  40. Furious_Styles
    Furious_Styles [H]ard|Gawd
    1,142
    Jan 16, 2013
    Agree with this post. I'll add that from personal experience if you hare doing 1440p @144-165hz just get the 1080 ti. Running those high refresh rates/fps it's really nice to have the horsepower to back it up.
