Best upgrade for 1920x1200
What is the best upgrade for 1920x1200, max settings, 4x AA, no more than $600-700
  • GTX 470 SLI
    Votes: 2 13.3%
  • GTX 480
    Votes: 4 26.7%
  • 5970
    Votes: 2 13.3%
  • Next gen HD6000 series top end
    Votes: 7 46.7%
  • Next gen GTX 580 or whatever is the top end.
    Votes: 0 0.0%
  • Total voters
    15
Nirad9er
What would be the best upgrade for 1920x1200 resolution for maximum in game settings and 4x AA.
I wouldn't spend more than $600-700.
your sig and time on here indicates you are pretty hardware knowledgeable. so are you really not capable of looking at all the benchmarks and drawing a conclusion yourself? :p
I know some of the benchmarks but would like an opinion unless I'm overlooking something.
I would wait on the gtx475(for sli) which will be the unlocked 384sp version of the gtx460. my guess is around 3-4 weeks and we should be seeing a confirmed launch date on those.
GTX480.
Although with a 4870X2, unless you have a game that is unplayable I probably wouldn't bother at this stage in the release cycle.
5970. Fastest card on the market. Not sure if its worth $680 or not but if you're willing to spend it, that's the most muscle you can buy.
But in all honesty, a GTX480 would be enough to max out 95% of games at 1920x1200, and maybe more.
