madmat said:The MCW60B comes sans ramsinks and you need an adaptor to use it with older nVidia cards but it's a good cooler and now there are no springs and nothing sticking up on the rear of the card unlike the Maze 4.
The Maze 4 is a royal PITA on both the A8N32-SLI and the MSI K8N Diamond. The ASUS ends up with all the PCI slots blocked off by the hardware and the MSI, the hardware hits the NB HSF.
Not fun at all.![]()
madmat said:The way that the MCW60B is made allows you to remove the chrome plate for the hardware and replace it. This is a fairly future-proof design in that it allows you to just change that piece should the mounting locations change in the future. I'd reckon that unless they do something radical to the mounting hole locations you should be good for some time to come.
Introvert said:I have a mcw60 on my vid and i thought i was not necessarily difficult to mount but awkward. Other than that it is top notch.
madmat said:QFT, trying to manipulate the parts, hold the card and line up the holes is awkward as hell. That's why I said being ambidexterous or having a helper are what's needed to make the job doable without losing one's mind in the process.
madmat said:I've seen that same thing with every stick-on ramsink I've encountered. OCZ, Koolance and Swiftech. The key I've found is to clean the ram very agressively with a solvent based cleaner such as Get OFF or OOPS then after the solvent has completely evaporated go over the ram with 91% (or higher if you can find it) isopropyl alcohol to remove any lingering solvent film.
I've done this with my 6800 and a pair of 7800GTX's and neither has suffered any loss of ramsinks after many, many repeated movings and the GTX's have been at the tender mercy of FedEX no less than 3 times with no sinks shook loose.
