Rydawg5143
- Apr 22, 2008
So I and goign to reseat my cpu and HSF and want to get some good 'goo' I have AS5 on there now, and it doesnt work very good
What is the best?
I use AS5 and I'm quite happy with it, but its very stiff and thick sometimes.
Are you sure the thermal compound is your real problem? From what I've read in reviews, the MX-2 is only 1-2 °C better than the AS5.
I use MX2 and its great but you should be happy with TX2 also. Remember, don't put too much this time!Looks like tx2 beat mx2, so i ordered some of that...... When i seated my hsf originally, im 100% certain i used too much as5 as i went with a friends recommendation and not what online guide said![]()
So the tx2 will be here tomorrow and we'll see hopefully i get this thing workign as it should cause the new system as it is today, is no better than my old amd athlon 64 x2 4000
I use Shin-Etsu x-23. Its kinda pricy and hard to find but cools 3-4 degrees better for me than as-5.
