Best storage solution for my setup.
rxteenager
Hi guys,
Hopefully next week i'll complete my I7 build(just waiting for the heatsink to arrive). I'm planning on buying another 2x 1.5TB hdd's. But I also wanted a GTX 460, because of budget limits I might not be able to buy these. So i'm left with the desicion of getting just 1hdd, i might have to go with a 1tb hdd.
My setup will be the following
Antec 300
Antec True power Trio 650w hdd
16GB DDR3 1333MHZ- Hynix
i7- 860
x2 128gb corsair ssd's in raid
x2 640gb wd hdd's in raid
Gigabyte UD3 motherboard.
Now since my motherboard has two sata controllers, one sata 2 and another sata 3. I'll be running the ssd's on one controller.
THE BIG QUESTION IS.
Could I use any raid setup to create a 1tb partition with the 2x 640gb hdd's + 1tb hdd??
Or would I be stuck with creating a raid 0 array with the 2x 640gb hdd's and backing it up with the 1tb hdd??
Any suggestions?
IIRC, Intel Matrix RAID will let you do that. But not 100% sure.
Also, it would not be a good idea at all for 640GB RAID 0 and backing up to the 1TB HDD. That's just seems like a recipe for disaster.
Well the only reason why I would make a RAID0 from the two 640gb hdd's would be to expand my storage capacity, they're currently in RAID1 and I know that if I add the 1tb hdd it'll still be 640 right? The information on those drives are mainly movies and game backups, I currently have an external 500gb hdd that's acting for backup to the most critical stuff family pictures and some of my favorite movies.
