best SFF case with handle
parawing742
I'm ready to build a new MicroATX system and I'd like to find a case that includes a sturdy built-in handle. Monarch Computer used to have a great one (the hornet?) before closing up shop.
I located a couple others on NewEgg:
Qpack2 - lots of reviews noting the handle and case in general is rather flimsy
Thermaltake LANBOX - weird DVD bay design which uses adapters to fit regular-sized drives
Can anyone recommend a SFF case which includes a handle?
You'd be surprised how worthless the handle is.
The Qpack 2 and variations have a handle that people claim is flimsy but I beat that thing it didn't break so don't worry about it.
The thermaltake LANBOX has the handle you are thinking of which is nice too but more expensive.
http://www.thermaltakeusa.com/Products.aspx?C=1415
The LANBOX has some space issues more so than the Qpack.
In reality, don't get the handle...it's not worth it :)
I've never owned a computer with a handle, but it just seems like it would be much more convenient to move. This particular system will be moved between two locations DAILY so ease of moving is going to be a criteria for sure. I'm currently using a laptop for the project, but the hassle of now 3 external drives is getting to be a bit much.
But now I'm curious: why don't you think handles are a good idea?
Thanks
A lot of people don't like handles solely for aesthetic reasons.
Also, it depends on the company and how well they implement the handle. Is the handle designed for occasional lifting and movement, or is it designed to regularly support the full load of the case? How it's implemented also sometimes gives people a major pause for concern over the case.
Anyway, you should also consider the Silverstone SG-04H/FH, along with the ones mentioned above.
SG04 with handle might be a good choice. Also many popular shoebox cases have some sort of available velcro harness that would be useful. These often have some sort of cable/accessory holders as well.
IIRC Silverstone also built the Hornet case for Monarch. From what I have heard that handle on the Lanbox is quite sturdy. When it first came out I remember discussions here about how you could use it as a weapon against someone (swinging it) and effectively knock someone out and it would probably still hold together it is that strong.
The two cases I would suggest to the OP, as far as having sturdy handles go, would be The Lanbox and the SG04. If you prefer a case without a handle but need a way to tote it around then I would suggest one of the Geargrip harnesses. I use a Geargrip on my SG03 and it works great.
If you buy your case from Performance-PCs or FrozenCPU, they can add case handles for an extra charge.
The Antec Lanboy came with a carrying strap, however it's a midtower case. On the plus side it is all aluminum. Antec Skeleton would be easy to drag around as well.
The Lanbox has the best design and handle, but the chassis is steel on all of the versions so it's going to be a bit heavier. I would say it is probably the best option, though. The handle route does not seem like a bad idea either, if you find a case you like and want to spend the $40-50.
Heyo;
Why a case with a handle?
I own a TT Lanbox Lite, and in all honesty the handle isn't that useful.
Its a well built cast, the handle is more then sufficient to hold it, but with all the stuff you will be putting inside the case, its going to get heavy. You will probably find yourself carrying it like you would a box, hands underneath supporting it.
Unless you are simply moving from room to room in your house, the handle wont make much of a difference in mobility.
While I haven't used one much, the handles on the QPack cases seem like their about to pop out when you pick the thing up with it. Perhaps it's just cause it's a lil plastic thing, but that's the feeling I got from it. But it was just me helping to put a number of them together not using it regularly.
And I'll second the Antec LanBoy if your not dead set on a SFF. The case it small, can hold a ton of drives, weighs next to nothing and has a tough as nails carrying strap. I used to use the strap from one to carry around a TT Armor which weighs ~20lbs with nothing in it.
Again, I've picked up the Qpack with the handle while fulling loaded with watercooling and twisted it and swung it...not problems breaking. Short of your beating someone with your case it will probably hold!
I have a Q Pack here at the office and the handle feels very flimsy. After, it might be solid enough.
That why I prefer Da Box for carrying purposes; we opted for a bag to carry it like a laptop. When it's loaded, it's fairly heavy but with a bag, it makes it tolerable.
Missed that part of your post earlier.
And you really were swinging it around?? :eek: You crazycrazy man... I never would do that even the handle were bolted to the frame... But I'm paranoid about breaking my computer and seat belt it into the car when I take it somewhere :D
I think one important factor that all of us overlooked was, while you mentioned that it would be moved daily for the project you are working in, you didn't indicate what type of distance we are talking about, and how long it would be carried for.
For example, if you take the bus, and have to stand, that's a much more significant amount of time that the handle will be under strain, versus simply driving in between home and the project location, and using the handle for a much shorter walking distance.
