I suppose sp120 may perform better on a thick high fpi radiator...google translate said:If we compare [the performance of the sp120 with] the performance of the Scythe Gentle Typhoon, 12V, for a slightly lower noise level (35.4 dB (A) vs 35.8 dB (A)), the Scythe offers a greater flow of air over the radiator off as restriction. Worse, if you compare it with the AF120 on the radiator, it is less efficient than the latter at equivalent speed! From there, why buy as specific as the SP120 fan since other more versatile do better?
Thanks for the reply guys.
I have decided I want to go all 140mm fans as120/140 adapters, original thought, will not fit with the Push/Pull configuration I want to do. I have 1x420 and 1x240 radiators. That's 10 fans x $$=$$$$$$
I originally thought of the Noctua's but their mmH2o rating is pretty low, they are $$$ pricey and Martin doesn't give them really good marks.
I looked at Corsair but they don't do a SP 140.
BGears has a BGears B-PWM 140mm x 25mm High Static Pressure PWM 1800rpm Fan that looks interesting but still pretty expensive $17+ after adding sheathing etc. Some reviews say they tend to be pretty loud at higher RPM's. Noise is not a killer but carries some weight.
