yes dood, thats the way the program is designed.
all the host is doing is storing a database file and some forms.
users on the lan, install a local copy of the program that tells the program to go to the P drive (host machine) for the data base.
a user can use the host machine just like a normal workstation.
so yes a remote user can connect to the server to do the work.
again, a backup has some form of offsite. if the office burns down your both fucked, since you get to tell him that data recovery will cost minimum of 1 grand, and that i was too ignorant to listen to people on the forum.
that second hard drive will cost you atleast 80 bucks, then labor for you to install and configure the backup software.
for 55 a year you can get away with running Mozy Home, that will encrypt the data and send to a offsite location and have revisions.
