CaseMod said:I've also considered it but I don't like the way it looks though. Although I would agree I've seen reviews about it.
excellent point. here are some examples of hard drive suspensions...sarbz said:...And if you truly want to quiet your HD, suspend it....
Drucifer said:Antec Sonata. 29db under full load with a reasonable CPU HSF... I love mine. SOOOO quiet.![]()
DR_K13 said:dont forget grommets, o-rings,dampners,insulation
http://www.directron.com/isolation.html
get some insulation here
you can make most cases quiet.
I don't believe those ratings just because it just looks too good to be true. SilenX doesn't make anything - all the products they market are re-branded from another manufacturer. The folks over at SPCR don't like SilenX products because the owner himself participated in some sketchy marketing schemes on the forums.HighwayAssassins said:check out these fans:
http://www.silenxusa.com/productcart/pc/configureprd_z.asp?idcategory=10&idproduct=38
120 MM pushes 40 CFM and is 11DBA. there is also another one that is 14DBA i think and pushed near 60CFM...
HighwayAssassins said:Hey DR_K13 did you just become a mod? I never noticed you were before...
anyways do you really think the insulation works? I mean its $50...does it dampen $50 worth of sound? And its just thoes sound foam pads right? I could just go down to ace hardware and pick some up couldnt i?
thanks and sorry about the double post
is that brand/those fans credible? id love to get my hands on some 120mms at only 11DBA. even something less than 20DBA would be excellent.HighwayAssassins said:check out these fans:
TSS Modder said:is that brand/those fans credible? id love to get my hands on some 120mms at only 11DBA. even something less than 20DBA would be excellent.
IceWind said:Those SilenX are proven to be pure utter crap, ask anyone at the SilentPCReview forums. The guy has even deliberatly lied about his companies products. I"d stay away from them.
SilenX Conspiracy
Not even that, SilenX fans are proven to be far from "silent" for the standards of the SPCR community. I certainly know they're not silent.MeanieMan said:and SilentPCreview would be biased because of what happen.
