Gaming
$150 plus tax/shipping
Huntington Beach, CA
Power Supply
RAM
Reusing:
EVGA 560ti
Antec P180B
Already purchased:
Asus P8Z77-V Pro
Intel Core i5 3570K
Cooler Master Hyper 212 Evo
6) Will you be overclocking?
Yes, CPU only.
1680x1050, 20"
This month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Motherboard already purchased.
Yes, Windows 7 64bit.
First up, power supply. I have no plans to go with multiple video cards, so I figure a ~500W power supply should be sufficient. What's my best option for around $100? I see the Antec Neo Eco units recommended here pretty regularly - are these good enough for overclocking?
I plan on buying this RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314. Can anyone confirm that the G Skill Ripjaws RAM I've picked out will fit under the Cooler Master Hyper 212 Evo CPU cooler on this motherboard?
