IMO, the Asrock boards are the most feature-rich for your dollar. I went with the P67 Extreme4 myself, I had a bad experience with Asus in the AM3 realm. Gigabyte offers high quality components but they just don't wow me the same way that they used to. It's the little things that make a big difference. Even my old Biostar AM2 board had more fan headers than my Gigabyte P45 did.
alot of people having issues with asus p67 boards, just read the forums...but if i was building a p67 setup now id have a hard time passing up the fatality board with my windowed case...but the more intellegent choise is the extreme 6...but i like the bling...the giga black p67 boards are very nice looking also...gigabyte has been building some awsome boards especially on the 1366 socket...
right now my dfi 1366 board is still feeding my thirst for bing with performance...go with the board you like the best, cant really go wrong with fatality or extreme 6...
Depends, i have the P8P67 deluxe board and i've zero problems with it so far. Luck of the draw i'd say. Still, any of the other boards mentioned are good.
Wow, I have both an Asus P8P67 Evo and a P8P67 Pro and they've been fantastic boards for me. Haven't had a single issue with them. ASRock is just Asus' lower end brand I think but they are great boards for the price and I've had good luck with the ones I used in builds for people.
I hadn't had any issues with either my B2 or B3 P8P67 Deluxe board, but last week I finally got hit by the freeze bug that from what I can tell affects a lot of people. Unfortunately this happened *right* as I needed the extra compute power for some VHDL simulations.
So if I can't get the board fixed in the next day or two, NewEgg has offered to RMA the board for a refund.
I'd avoid ASUS altogether. They don't respond to my support inquiries, don't make boards that work out of the box, and they just give me the general feeling that I am a beta tester for them.
Zero issues with the sabertooth p67 so far, fairly aggressive overclock and tried all kinds of voltages on all different components, took it all like a champ. In fact, I'm running all secondary components at downclocked voltage now and still 100% stable, only thing that's power hungry is this 2600k.
Well, if by best you are looking for TONS of features, lots of performance and way,way over engineered, then the ASUS Maximus IV Extreme pretty much floats to the top of the pack. But it doesn't come cheap!
IM more looking for a solid overclocker, good chipset temps and not too much I don't need.
So I think the Asrock extreme 6 ticks all the boxes.
Sata 6
Dual Gigabit lan
Handles OC very well (from a few reviews)
Chipset temps very good under load (again from reviews)
PCI-E does 8x-8x in case I want to add another card later.
I have a Sabertooth also, most consistent board since launch. Some of the other boards had a few issues to iron out.
Now I'm getting a Maximus IV Extreme since it's time to replace my B2 revision.
I'm still not a fan of Asrock's 1-2 year warranty and lack of BIOS/driver updates. ASUS has better support and more desirable on the second hand market.
It would be hard to resell that flashy Fatality board. I wouldn't place that no where near or in my PC, much less his face on the BIOS background.
