Best oc mobo and ram
Fox_T
What is the best motherboard out now for 6600? and ram? I need it to be fast and with good overclocking capabilities. Are there any new upcoming releases I should wait for(if its less than 2 months)
If anyone got a link to mb comparision, it would help too.
Thanks in advance.
Ok put it this way: Intel d975xbx2 vs Asus comando (for overclocking means)
Memory...if you want the highest OCing stuff, look for something based on the Micron D9 chips. The uber-high-end Corsair, etc. is based off of that AFAIK. You need something with a lot of memory voltage options. From what I hear the Intel Bad Axe 2 is a good OCer. I have a P5W DH which is also nice, but it has a VDroop issue like just about every Asus motherboard.
680i boards seem to be hit or miss. You might get a good one or you might not. A 965 board is good also, but there seem to be less options available in the high end segment. Maybe an Asus Commando or P5B Deluxe or even a Gigabyte DQ6 (newer revision).
Edit: Oops...missed your 2nd post.
I'd go with the BX2 over the Commando, but that's just me. I'm sure others have their opinions also.
Thank you for the input, alot of people suggest d975xbx2, but from this thread it looks as if asus done a better job - http://www.hardforum.com/showthread.php?t=1138241 (e6600)
I don't know... this shit is so confusing
Those results don't look like they've been updated in a while. I'd be shocked if the XBX2 didn't do as well or better than a lot of those boards. My own personal experience is that my 975X P5W DH OC's my E6600 better than my old P965 DS3. Maybe 100mhz difference top end. Either one would probably OC well though.
