Best nonconductive grease?
Sojuuk
as the title says. what is the best non-conductive thermal grease?
haven't really bothered with expensive kinds since P4 days but I am building a SFF system and I need to do it absolutely right. PLEASE help.
also I did search the forums and turned up little info. coulda sworn [H] did a review of the available compounds but now I can't find it :(
Arctic Silver MX2, Shin Etsu X23.
It's normally just called "thermal paste" -- your throwing "non conductive grease" in there made me think you were setting up a phase system, and I was about to come in here and recommend Dow Corning 12, which is a thermal insulator! Wouldn't have done you a bit of good.
You can also try searching for TIM (thermal interface material). And with either you will find more than enough reading, however most good quality TIM's will state in the specs whether or not they are conductive, and so is straight forward to find out. However you will find people all across the board on what the "best" is.
I myself use Coollaboratory Liquid PRO and found it to have a 3C drop on a already lapped HSF and IHS. But being that it is a "liquid metal" it is without a doubt conductive.
OCZ Freeze will give you the best performance. Although I haven't used MX-2, from what I've read, OCZ freeze is a bit harder to apply, but the performance gain is worth it. Both are non conductive.
Arctic Ceramique is also non conductive, and doesn't need to go off to take effect on the temps.
I believe that the MX-2 and Arctic Ceramique were in the top 3 or 4 thermal compounds to use.
Another TIM comparison review:
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=138&Itemid=62
The majority of TIMs would be electrically non-conductive. Even the well known Arctic Silver 5 (where you would assume it is electrically conductive) states that is isn't (only slightly capacitive). Just don't spread anything on so thick that it oozes out and onto pins, tracks or sockets and you should be fine.
Yep, the freeze is good stuff. It is a little hard to work with, but it's worth the effort.
I've used Shin Etsu Microsi, IC-7, MX-2 AS5 and the tuniq paste (not sure of the model) so far I've had the best results with IC7 and the MX2. If your dealing with lapped surfaces or mirror surfaces the IC-7 may scratch it up a little. MX2 is a bit easier to apply and offers +-1C temps. Both are non conductive.
