Best MOBO for ME (E6600)
I am COMPLETELY torn between the ASUS P5W DH DELUXE and the EVGA 122-CK-NF68-AR. 680i with all it pros/cons vs 975X and all it's got. To SLI or not. Upcoming quad cores to think about. It's overwhelming.
Basically I use my computer to play games, build web pages, do some video editing, mix music...a little of everything. I'm not going to use SLI initially, but would like the option in the future if all other things are equal. I don't need the wifi of the p5w, but it might come in handy if all things are equal. I would like to try and overclock just a little, but I'm not pushing it to the edge. I just don't know. What do you folks think?
Right now, it seems like the P5W DH is a little less buggy. That's not to say you wouldn't have a good experience with the eVGA board. I guess if you really think you're going to use SLI, you don't really have a choice. You can always add a wireless USB adapter later if you think you want it to the eVGA, but you can't add SLI support. Both will overclock well enough for your purposes I would think.
I don't think you can go wrong either way. The P5W seems to be a little cheaper right now ($20 cheaper or so). I bought the P5W before the 680i came out, and I don't see any reason to switch out to the newer board at the moment. A single 8800GTX is enough for me and my 24" LCD.
Also consider the Intel D975XBX2 (BadAxe2). If you think you "might" want to go SLI in the future, by the time you do, the next generation will probably be out and a single card will be faster than two of whatever it is you have at the time. That's not guaranteed, but look at the 7900 series in SLI vs. a single 8800...
I had a pretty stable 680i, but the "optional" SPP (NB) fan is anything but. You have to run it, and it is loud. You can control the fan speed and lower it, but it still makes noise. I have an XBX2 with my E6600 at 9x400, and the NB is passively cooled. It gets hot, but it's stable. If noise is a concern for you at all, make sure you consider that when selecting a board.
And don't forget, Intel's new chipset (Broadwater) hits pretty soon....;)
the p5w dh deluxe has crossfire (which is like SLi but for ATi) but if youre only into nvidia then thats a tough call. ati cards are just as great and their new cards should be announced soon.
i would get the p5w, i think this board is amazing personally. great overclocker, wifi, remote control, plenty of ports, etc. personally i like ATi better anyway, im expecting great things from their new video cards
