Best Micro ATX Board
Probably the biostar T-force s939 board since it is a good all around board for OCing and features (no firewire and only the 6100 chipset, but other than that it's great). There is a whole sticky thread dedicated to the topic of mATX boards in the SFF section of the forum. They would have better answers IMHO.
Check the SFF section but for me it would be:
Foxconn 6150K8MA-8EKRS or the EVGA mATX SLi motherboard. Personally I would stick with the 6150 motherboard from Foxconn as rock solid, great features and decent overclocker
I vote for the Nvidia 6150 matx motherboards also. I wouldn't consider the Foxconn the "best" because it doesn't have a DVI port on it like the Asus and MSI boards do. That means if you wanted to use the built in video on a LCD TV or monitor you'ld be stuck with analog connections.
I have had the BioStar and the Asus and keep going back to the Foxconn for my builds. They are more stable and foxconn is the biggest mobo manufacter out there. Foxconn has just released a new model with DVI onboard and chipset voltage control. The Asus and MSI just aren't in the same league
Good to know. I'll have to look into that Foxconn if it has DVI.
Moonraker7 said:
Does anyone have suggestions on the best socket 939 Micro ATX motherboards
If you wanna go SLI, then eVGA's m-ATX is a good board. If you want the nForce 6100 series chipset, go with the Biostar. You can get all these answers in the SFF forums. Check out the stickies that Dillusion has posted.
-E
i had the tforce since october, i recently upgraded to the dfi rs482 infinity and its a much better board, has just about all features listed above (except sli) and is a great overclocker also. including onboard dvi.
I prefer the evga sli matx board, awesome board.
If your not wanting to run SLi then its a bit pointless. I maintain the Foxconn 6150 is the best board out there. I have tried quite a few mATX boards and the Foxconn rules!
That's good info -- so may people jump on the Biostar and seem to have bad results with the lan port.
So far, i believe the Foxconn 6150 is the best board. The Biostar TForce gave me issues with my Gskill ram, that have been remedied with the Foxconn. I believe there are now 2 varients of the Foxconn 6150 w/Firewire, one that has 3 PCI slots and one that has 2 PCI and a PCI-E x1. I have the 3 PCI varient and even with my 7900GTX, 2 of the slots are physically accessable (though one is RIGHT up against the cooler).
Edit : I'm also told that the DFI is a superior board, but since I plan to run linux on this box eventually, I stay away from ATI. If that's not a consideration for you, then go for it! It does have DVI and the like.
the dfi is about $30 more than the tforce, and well worth it. tv out, dvi out, better sound, better layout, more sata ports, etc. now going for $89 at newegg, so there is only a $20 diff. for my purposes (htpc/pvr) it is a much better board than the tforce, which i used for about 8 months, and much better than the foxconn, which i used for about a week. the tforce would run my opty 144 @ 9x300, the foxconn ran it @ 9x270. the dfi runs it at 340x9 (decent air), which is the same speed it runs on an ultra-d.
Why is it pointless? Its a stable board with nice features.
If you wanna run SLI then it is a bit pointless. ;)
It just depends on what you want to put in your SFF that matters. I believe you cannot go wrong with either board.
-E
Ive got the Biostar Tforce 6100 and it is a great board. I love it. Overclocks well and is fairly stable.
But not much of a clocker though and EVGA seem crap with their support specially BIOS updates.
my lovely little Foxconn 6150 runs my OCZ Platinum Rev.2 TCCD at 2-2-2-5 with 1T command rates at 2.7V. Hasn't gone unstable on me yet! This board is rock solid.
