Best Memory for ASUS P5K-E
Sob Rogue
I'm building a mid-line gaming computer around the P5K-E board, but am uncertain at what memory will play well.
I'm using the E8400 and want to take advantage of faster memory speeds.
I was thinking that the best economical memory on the market right now is the PC8500.
Is this the right choice? And if so, I was looking @ Kingston HyperX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134218
Would this play nice, and handle everything that I need, aka lightning fast for games, although its not on the M/B list of compatible Memory sticks
Only thing that scares be about this memory is that everyone has to manually clock it, I'm not afraid to do this and have done it before, but don't understand why this happens. Why advertising it as 1066 when its stock is 800? Maybe there something that I'm just missing, but thats my only complaint/ worry.
Any other good suggestions, that won't make my wallet hurt?
Thanks
OK do note that C2D systems do not benefit in real world apps and games with faster RAM. In fact, C2D systems perform best when the RAM and FSB are a 1:1 ratio. The only time when faster RAM would be useful in a C2D system is for overclocking purposes. Some math:
Stated FSB/4 = Actual FSB
Multiplier x Actual FSB = CPU Speed
1:1 Ratio: 2 x Actual FSB = RAM Speed
1:1 Ratio: FSB = 1/2 RAM speed
E8400:
Multi x Actual FSB, RAM Speed = Clock Speed
9 x 333Mhz, DDR2 667 RAM = 3.0Ghz <== Stock Speeds
9 x 400Mhz, DDR2 800 RAM = 3.6Ghz <== Easy OC
9 x 450Mhz, DDR2 900 RAM = 4.0Ghz <== Good OC
9 x 500Mhz, DDR2 1000 RAM = 4.5Ghz <== Excellent OC
So basically, don't go for that DDR2 1066 RAM. If you're not overclocking, no need for it. If you are overclocking, this G.Skill set is the better deal:
G.SKILL F2-8000CL5D-4GBPQ 2 x 2GB DDR2 1000 RAM - $90
As for why that HyperX RAM is downclocked to DDR2 800 RAM speeds, could be that those mobos don't support DDR2 1066 RAM officially.
Thanks Danny,
If this is the case, would it be any different if I chose a Quad Core instead?
I'm not really understanding why this board is advertising as "Native 1066" then.
Thanks
The reason people have to over clock RAM at that value is because it goes beyond JDEC standards. Things like 1.8 volt 5.5.5.5.18 timing are industry standard.
That’s not to say you can go above that but keep a few things in mind. On most motherboards the RAM you are looking at is rated at 2.0 volts and above, so there is a very high chance you won’t be able to boot right off the bat. Grab a stick of DDR2 econo ram to boot, then bump your ram voltages in BIOS to 2.0 save and exit. Then you can install your new RAM and yes, you will have to adjust timings manually because as said, you are technically out of spec.
Now, here is where many people get in trouble and that is during a bios flash. You have your 2.0 to 2.? Volt ram installed, you drop your fsb to stock speed and attempt a flash. During the flash the flash program reads it’s contents into RAM which is fine but the flash file can and usually does reset everything back to stock. Boom, pooched BIOS flash and probably an RMA.
Flash the BIOS with the cheapo ram at stock settings to avoid this issue.
Luck man;)
