ForBuilding
- Nov 30, 2005
Hi guys,
My system is in my sig, and I was planning on getting 2x1GB sticks of RAM for my computer. Currently, I have 4x512MB and I've heard having 4 sticks can result in a hit in performance.
Since, I have a Dell, which is not easy/impossible to overclock, I wonder, what is the best memory? Dell's mobo or bios has also somehow screwed it up so that the highest frequency it supports is DDR-667 RAM even though it should be DDR-800. With that said, I know there is not much of a difference between 533 and 667 and it probably comes down to CL. But then, I cannot even see, nor adjust CL on a Dell mobo... so what memory should I get?
DDR-667 Kingstons
http://www.newegg.com/Product/Product.asp?Item=N82E16820134384
some nicer DDR-667 pqi's, but i won't be able to adjust cas latencies/voltages so I think the CL will end up being 5.
http://www.newegg.com/Product/Product.asp?Item=N82E16820141211
some low latency DDR-533 from G.skill
http://www.newegg.com/Product/Product.asp?Item=N82E16820231044
DDR-667 Kingstons
