Ever try to install Linux natively on a Surface Pro 3?
Ever try to install Windows natively on an HP TouchPad?
Don't work.
Don't work.
Ever try to install Linux natively on a Surface Pro 3? I did about a year ago with Ubuntu, that was the last time installed Linux natively. I've installed Linux many times over the years on all kinds of hardware. Works fine on basic hardware. Not so much for things like a Surface Pro 3. Might try it out this weekend on my Surface Book. I have a pretty good idea that the tablet features won't be there. I'll look around to see what people are doing.
As I've said, I do keep up with the state of desktop Linux in terms of its hardware and software support. I have a pretty good idea of what works and doesn't relative to Windows for the things I do.
tek syndicate went through this not too long ago and listed a bunch of issues and how they got it working. They did a video on it and posted their info in the forums. It was interesting overall.
What's interesting as well is his mention of OneNote at the end and seeking a FOSS equivalent. As much as some think top line tools like OneNote are for the 1% and hardware like a Surface Pro are niche, desktop Linux simply isn't going to become mainstream without support for this kind of stuff. Support for top end stuff is critical to a platform because that stuff trickles down the chain and pushes things forward.
And... it's moving that way and is why I'm supportive of Valve. Valve bringing Steam to Linux has given it a monetizing app store that works (in that it is established and runs.) No doubt the next few months will be interesting for developers as they begin to push it. If it's successful, it wouldn't be out of the realm of possibility for groups like Adobe to make "holy grail" software, like Photoshop, available. As unlikely as I think it would be to ever see OneNote on Linux, I guess I didn't expect to see it on OSX either, and there it is.
Same with hardware. If SteamMachines were to get traction (I'm honestly skeptical but hope they do well) then you'll see more direct support from corporate engineering types. "Why won't you use our chip in your console?" will be asked and the suits will hear "linux" and have a business decision to make that can only leave linux in a better spot than it is in today.
Go be an egg.. or chicken.. whatever one comes first.
IMO, the Surface is just an outlier in the hardware discussion due to conflict of interests. Microsoft has zero reason to support Linux by choosing supported components, nor contributing code for what they created. They even went to the trouble of enabling Secure Boot on the Windows RT devices to discourage alternate OS use. I just can't lay blame at the efforts of Linux developers for that platform not working correctly, should it not.
However the point is where are the cool and interesting PC designs running desktop Linux?
That's not going to happen because the future for PCs isn't very bright. It's a dying market except maybe in China.
Though IMO there hasn't been anything really cool and interesting in the PC space for years, but that's just because I'm not impressed by much. Monopolies don't exactly inspire innovation either, of course.
Zarathustra[H];1041934449 said:Complaining that an OS doesn't work on niche hardware and software (Microsoft Surface, One Note) and using that to damn the OS overall seems rather silly to me.
Zarathustra[H];1041934449 said:It's just kind of annoying that every time anyone posts anything about Linux, like for instance this thread intending to compare distributions to each other. (Last I checked Windows is not a linux distribution), especially as it were, in the linux subforum, trolls feel the need to come in and bash linux because it doesn't do some obscure thing that no one uses, or it doesn't run on some obscure hardware that no one owns.
Basing your experiences with a modern Linux Distro using s surface Pro 3 as an example Application support and quality of applications under Linux isn't as bad as you make them out to be - Coming from someone that runs both a Linux and a high end Windows PC. If you work in a niche professional field use whatever OS works best for you - But understand that you're the minority.
Often when alternative software is mentioned in these types of discussions the software has Windows support. Two such that are frequently mentioned are GIMP and Libre Office. So what's the point of switching OSes for that? Most people couldn't care less about the OS and are much more interested in hardware and software support because those are the things that they use, the OS tends to fade to back. That's why support for top line hardware and software is important for mainstream adoption.
nitpick, but.. it's an OS subforum. The point of it is for people to discuss the OS. Else it'd be a subforum under General Software. The primary topic is working with the OS.
GIMP and Libre Office let you image manipulate and do officey things WHILE running Linux, and so they come up in discussions about running Linux. I'm sure there's one out there, but largely no-one says they moved to Linux for the pleasure of GIMP and Libre Office. However, someone will need to crop an image or type a letter, so it comes up in conversation. I'm sure they're aware that it's available on another platform, but it just doesn't matter in the context created by the forum organization.
Zarathustra[H];1041934893 said:Exactly.
These pieces of software are brought up because they mean you can enjoy a superior operating system, and still do the work you need to do.
The operating system itself is the draw. These software packages make it livable, as otherwise you'd have to constantly dual boot in order to get your stuff done.
If said operating system is so superior, why would one need to change what they are doing for apps they could use on the supposedly inferior operating system in addition to ones not available on the supposedly superior OS?
Most of the Linux alternatives that people mention in threads like this are supported by Windows and OS X. I use a number of these apps and I didn't need to change OSes or totally change everything I was doing to use them.
Now you're just being "that guy." You've seen "that guy".. he's the one that goes to the Honda enthusiast forums and talks about how great Chevy is. Don't be "that guy."
There's any number of reasons to dislike Chevy.. err Microsoft... and it doesn't necessarily have to do with technical merit of the products.
But also without going into a niche field, you cant say you can do something on Windows or Linux that can't be done on the other either.
If someone doesn't like Windows or Microsoft then more power to them. But when the subject of software like OneNote comes up and people compare to a sticky notes app or something for doodling, in a forum like this with a good number of people that swear by OneNote, you've just become "that guy".
There's nothing inherently wrong with desktop Linux. But the idea that powerful applications and hardware are niche or irrelevant and if people just stopped being lazy or stupid then they'd clearly see the greatness of Linux is not a winning argument. If it were world would have largely stopped using Windows years ago as the ecosystem is the really the only reason to use Windows.
In theory this is true. In theory a Windows Phone should be able to do everything an iPhone does except in reality it doesn't.
OneNote is just an example. So is any legal/commercial Blu-ray player. So is Lightroom. So is Photoshop. So are Word, Excel, and Outlook. So are a dozen actual niche software products.
And... iTunes. There is no replacement for iTunes on Linux.
Yes, no one of these applications is required by most people, but when you add up all the people who really want at least one of them it's rather significant.
One cannot conclude the superiority or inferiority of one operating system to another based on the third party software that is available for it.OneNote is just an example. So is any legal/commercial Blu-ray player. So is Lightroom. So is Photoshop. So are Word, Excel, and Outlook. So are a dozen actual niche software products.
I will give you iTunes. The windows client of iTunes is frankly terrible as I am sure it is meant to be. Its really for OS X. My feelings with this program has always been "let people that fell into this trap stay in it."
Word/Excel/Outlook have linux equivalences. Unless you absolutely have to have it say
Microsoft or (imo) are doing extensive work with access then you don't need office. I used Libre office in an office environment daily for over a year before anyone even knew I wasn't using Microsoft office.
One note specifically was created to compete with Evernote which actually has a Linux based client (everpad?)
The only thing I will give you is BR players but that is because it's heavily laden with DRM which we should ALL be willing to stand up against on principle if nothing else. Even so, I rip my BR discs (on Linux) and watch them on Linux anyway. This is no barrier to entry as 99% of PC users are not watching their BR's on their desktops.
It is not likely that Microsoft will release their products on Linux in general or targeted to a specific distribution of Linux in particular. It doesn't make sense for them. The cost of doing so or effort required isn't exceeded by the benefit, revenue, or profit of doing so.
If you are a user who cannot part with the iWork Suite, GarageBand, Parallels, FileMaker, iMovie, etc., would you then say Microsoft Windows was completely inferior to Mac OS X? Is Mac OS X functionally equivalent to Windows because it has "OneNote, legal/commercial Blu-ray player, Lightroom, Photoshop, Word, Excel, and Outlook" and both clearly superior to Linux, Unix, XNU, etc?
Sound silly to me.
Word/Excel/Outlook have linux equivalences. Unless you absolutely have to have it say Microsoft or (imo) are doing extensive work with access then you don't need office. I used Libre office in an office environment daily for over a year before anyone even knew I wasn't using Microsoft office.
Photoshop is unquestioningly a very niche program and unless you are doing it on a professional level there are pretty good Linux equivalences as well. You cannot say you cannot do photo editing on Linux without being disingenuous. It's just that one specific program set (Which if you need fine, use Mac or Windows.)
If you do any work with other people, you're pretty much locked into MS Office. Compatibility between Word/Excel/PP and other programs is basically nonexistent.
OneNote was not created to compete with Evernote. OneNote predates Evernote by over a decade.
FYI, the abbreviation for Blu-ray is BD, not BR. Took me a minute to figure out what you meant.
So, yeah, my point stands. People like to pretend that 99+% of people can get away with Linux just fine, and that's simply not true.
I am not trying to have a philosophical debate. I am merely suggesting that if we're comparing Operating Systems, in an Operating System thread, we compare them as operating systems, not as collections of available software. At that point, you're talking about software ecosystems or App Stores, and this would be better discussed in a General Software thread. Also, how does this discussion help the original poster, who was looking for the Linux distribution which would be easiest to transition to from a Windows background.Whether or not this is true it's hardly the kind of thing that matters to average people. Computers are tools for most. Not a philosophical debate about the definition of superiority.
I agree. And if it's a problem for Microsoft it's probably a problem for most software developers who have nowhere near Microsoft's resources.
Apple's ecosystem is one reason why it has such a loyal following though it's much bigger on the mobile side but that does trickle down a bit to desktops/laptops.
I own a Samsung Chromebook. I do not work in education. I have seen people using Chromebooks in Starbucks. Still haven't seen a single Surface Book or Surface Pro at Starbucks. Chromebooks would be great for parents with children, those who need a secure environment to access the internet, and possibly those concerned about using their laptop in an environment not under their control.If OEMs could eschew Windows licensing and save that money and put free to install Linux on their PCs and 99% of their customers would have no problems with it they'd have done it a LONG time ago especially after all of the anti-trust issues Microsoft had. Indeed all of them make Chromebooks but those have done zilch outside of the primary education market because of their cost.
With Microsoft getting into high end devices now I imagine that all of the OEMs are looking for alternatives if and when the day comes that Microsoft gets into the mainstream PC market. Which is one reason why I don't think Microsoft is going to go there unless they absolutely have to.
Pen enabled devices are a true strength of Windows. They have put a ton of R&D into it and I was impressed when I first used a pen on a SP3. If you used it frequently I would advocate you stay on windows. They are a fairly uncommon and expensive device though (in my experience.)
But for the majority of users doing homework, typing letters/correspondence, editing a resume, etc there is nothing in Office 2016 that Libre does not also provide.
I honestly think the great barriers to linux are not BR or Office/OneNote. I think it's difficulty and ease of use. As more third party support starts heading towards Linux I think we will slowly see this erode.
You guys should post up / redirect some of this energy into the Linux Programs thread. That thing had not been updated in like 5 years.
Sorry, I misunderstood and made that assumption. It just seemed like ganging up on Linux because certain companies aren't releasing their software on it.I never said one is superior to the other.
Linux is superior to Windows in many ways, and for many use cases.
