I'm currently running an E8400 overclocked to 3.8ghz on 1.30V using a zalman 9700 and temps are reaching around 70C under load in bad company 2 =\
I'm wondering what air heatsink you recommend to get this thing as cool as possible. Also, does this mean that I will have to remove the entire mobo to replace the bracket under it for the new heatsink?
Thanks
Thanks
