Best I7 MB?
bratboy
Who makes the best I7 965 EE supporting MB. I want a MB that will support 6 x 2 GB Corsair Dominator 1600 memory chips, TR3X6G1600C8D, in Triple channel mode
A bit dated info, ain't it?
There are more choices other than ASUS and EVGA now and changing almost daily. That thread is like 20 days old.
I like the looks of the P6T myself but I hear it doesn't come out of sleep well (but then none of the x58 boards seem to do that well. I hear Gigabyte doesn't do it at all.) and doesnt support "Turbo" mode (nor get around the TDP lockout it seems).
Gigabyte seems like it's inexpensive but is picky on memory.
MSI Plat doesn't seem to give enough options on overclocking.
The list seems to go on and on. There just doesn't seem to be a single GREAT board yet.
So here I sit, much like the OP, with a 920 and 6GB 1600 and no motherboard.
I still think that the evga board is the best. The only thing I don't like about it is the PCI Express x1 slot is directly under the main video card slot. So, unless I want to clock down my other PCI-E x16 slots to x8 and x1 respectively, I can't use my other video card. This is fixed on the new Classified version though. :)
Im posting another vote for the P6T Deluxe - im having great luck with it and it takes minor adjustments to oc
I'm considering it but one question. I use a MS wireless Keyboard and a Logitech wireles mouse, both of which I connect to my current system via PS2 connectors. Anyway I notice the back connectors only offer one PS2 Mouse/Keyboard combo connector. Does the motherboard come with some sort of adapter of would I need to connect the mouse via a usb port?
The motherboards would not come with a Keyboard or Mouse PS2 to USB adapter. Most MS accessory products come with the adapter in the packaging.
I am odering componnents for my i7 build. So fat the P6T Deluxe is on my short list. Did you consider the RAmpage II or the P6T OC palm also? What about the P6T D Ver II?
P6T Deluxe is solid, definitely recommend it. The OC Palm isn't all that good, not worth the extra. The Rampage is the top model P6T with all the bells and whistles, you'd have to decide yourself if you need it.
Gigabyte Extreme, Asus's ROG board, or the up-coming EVGA Classified would be top of the list.
You live fast, ain't ya? What exactly has changed in 20 days to increse the number of choices? Everything you discuss here was already talked to death in various threads in intel sub-forum (look here, for example: http://www.hardforum.com/showthread.php?t=1383765, it's even older and yet, the issues covered are still current). You are right about one thing though - there are NO great x58 boards, and I seriously doubt that the upcoming EVGA Classified won't have bugs of its own.
I have the EVGA X58 SLI and I really like it.
I had a number of reasons for chosing it, but it all boils down to personal choice at this point.
The evga board is very solid, I really can't find anything wrong with it.
My 920 is running rock solid at 4.0 GHz.
There are plenty of slots for everything I use.
It will have no problem with triple SLi if I ever want it.
My main reason in chosing this board was I could run SLi and still use my older X-Fi PCI card with no problems and the customer service is second to none. EVGA forums are also very well staffed by their techs and often solutions can be found there instead of calling or emailing.
There is a new "Classified" EVGA board coming out that looks to be a real monster.....but it also costs $450.....:eek::eek:
I've seen very good reviews of the EVGA,ASUS P6T, and Gigabyte X58-UD5......it just comes down to personal preferences.
I didnt want to spend the extra money on the OC Palm thing so no and i did not look at teh rampage II, and ver 2 of the p6T was not out so my options were limited
Elcheapopc, I have the Gigabyte GA-EX58-UD4P. I can sleep my pc just fine never had a problem with that. As far a memory they are updating their bios to support more memory. I have Corsair Dominator DDR3 1333 6g(3X2g), and I haven't had one BSOD or lockup or anything. As for OC'ing you may be right, but I don't plan on OC'ing mine very much at all so it fits my needs VERY well! These new MOBO I7 configs. are Hella fast too!!!!!
How do we determine who the "best" is? All I see here is "I like this one, I bought it." ...
There are some better choices, me thinks, like the P6T Deluxe and EVGA X58 being the top 2 (with the latter being the most popular I believe). Heard good things about Foxconn's Bloodrage.
Seeing some clocks from xs, i like the dfi x58
Evgas upcoming board looks decent as well.
