bloodhawke83
I Strike Fear into the Hearts of the Masses
- Oct 8, 2010
best free encryption sw for storage drive? i just for one folder with many files.
runnig windows 7 64bit
What will happen when a part of a TrueCrypt volume becomes corrupted?
In encrypted data, one corrupted bit usually corrupts the whole ciphertext block in which it occurred. The ciphertext block size used by TrueCrypt is 16 bytes (i.e., 128 bits). The mode of operation used by TrueCrypt ensures that if data corruption occurs within a block, the remaining blocks are not affected. See also the question 'What do I do when the encrypted filesystem on my TrueCrypt volume is corrupted?
File system within a TrueCrypt volume may become corrupted in the same way as any normal unencrypted file system. When that happens, you can use filesystem repair tools supplied with your operating system to fix it. In Windows, it is the 'chkdsk' tool. TrueCrypt provides an easy way to use this tool on a TrueCrypt volume: Right-click the mounted volume in the main TrueCrypt window (in the drive list) and from the context menu select 'Repair Filesystem'.
TrueCrypt is capable of encrypting existing data. Also, regarding data corruption, this is from their faq:
It is a very impressive little app....
Also, on my array I plan on having the controller scrub it once every two weeks or so.
It truly sound like a great app. This was something i was worried about also. How do did you set up that "scrup" what is the technical name for that? i have adaptec controller if that important.
Also you say that it can encrypt exiting data, how is that done, not a container i presume?
Even across arrays?you load the container file and enter the password.
Even across arrays?
Have you recovered a container before? Is it as easy as you say?
I wish TC had the ability to share an encrypted drive across the network and mount it on the client. It's only supported for file containers.
Truecrypt. Also, if you have an i5/i7 it will do hardware AES. I'm building a 8 drive Raid 6 tomorrow that will be entirely encrypted w/ Truecrypt.![]()
Only if you have a newer i7 processor.
Will my CPU support hardware? Xeon W3570 3.20Ghz
