best computer to look into?
NPavao1991
Hey, I'm just getting into computers and I'm looking to replace my current computer. I just need a tower and I'm looking to spend between $500-$700. Any suggestions for best performance at that cost? My current computer is a HP notebook, and it's out of date with a cracked screen, so really anything would be an upgrade.
Here on these forums we generally build desktop machines for ourselves. Although you mention laptop which I wouldn't recommend building in that case. What exactly are you looking for?
Also if you are looking for build advice answer the questions in the sticky on the top of this sub forum. Please put the answers in this thread.
In addition to drescherjm's post, please clarify whether you want to assemble/build it yourself or just want assistance in selecting a pre-assembled product (ie: Dell).
I saw something on one of the threads that suggested looking at a pre-built computer if your budget is under $1000, so I was leaning towards pre-built. Can I realistically build a good computer for $700?
I want a desk top since that seems to be the better option for performance. I have never actually built a computer from scratch but would love to try. I've taken quite a few apart and put them back together, so if I can build one I'd love to.
Yes, but it's unknown whether such as computer is adequate for your needs. Please follow drescherjm's instructions:
Mainly web browsing. Mild gaming. Streaming Movies.
$700 After tax and shipping
I live in the US, Selmer TN
I need Motherboard, CPU, RAM, Case, CD/DVD drive, HDD, PSU, CPU fan (does this come with the CPU?), cooling system.
Not re-using anything.
6) Will you be overclocking?
no
My monitor will be 32". I'll be using a TV screen, not totally sure of the resolution.
6 mo. to a year
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Firewire, USB 2.0, onboard video as main GPU, onboard sound card. I think that's all I really need.
I don't. I want to purchase either 7 home premium x64 or 8. I don't know anything about 8 though.
As PTNL said, you're planning the build too early. Our parts recommendations can change in as little as a week let alone six to a year from a now. If you want to build an up-to-date PC, I'd start planning no earlier than a month (preferable 1-3 weeks) in advance of you actually buying the parts for the PC.
With that said, what exactly do you mean by "mild gaming"?
I think you'd be hard pressed to find a 32" LCD with a 1080p resolution, so I'd bet that 720p would be typical.
Coupled with your "mild gaming", then you might just be perfectly happy with an integrated GPU, though I still cry a little inside when I think of such things...
Maybe I just haven't given the integrated GPU's a fair chance at a low resolution. They probably work fine at 720p.
The Trinity APU's are pretty decent at that resolution.
