Best case under $50 with no window
Just looking to buy multiple very cheap cases for a lan setup. Would like something that looks alright with no window. Fans and sirflow isn't a huge concern just need to be able to fit a regular sized mobo/video card in them.
Antec 300 i believe is about $50 and I have heard it is an awsome case for the price.....would recoomend a LAN party case, but they have windows, and are expensive...lol
I'd get a 300. The budget coolermasters are ok if you absolutely can't spend the extra $$ for the 300.
coolermaster elite 330. enough room to fit long video cards like the 4850x2. by the looks of it, uses the same chassis frame as the tagan. i like the look of the coolermaster front bezel.
Ya they use that chassis a lot and slap different faces on them. They should get the job done pretty good. I just looked at the current prices of the 300 and they jumped up quite a bit, so I may have to agree with the posts above.
im in the same situation. I'm building a computer for my cousin. Im looking for a good cheap case too!!! and this thread has helped. only thing is im going to but a custom window on it but still haven't decided on a case. I bought antec 300 for another build and i liked it alot. The other cases seem good too. One thing i like about the antec case is the top 140mm fan. im still thinking which one i should buy!!! you guys think the antec 300 will drop in price black friday????
butterfliesrpretty id say get the antec 300.
