Worse cooling than Tsunami and more expensiveAuroraProject said:
zA.Gosu said:Praetorian looks like the one to get, no?
saturnine2 said:Worse cooling than Tsunami and more expensiveThat Praetorian is pretty good though.
http://www.newegg.com/app/ViewProductDesc.asp?description=11-133-132&depa=0
True, but the loud stock fans can be easily replaced with near silent 150mm fans. Big plus IMO.BossNoodleKaboodle said:The Cooling is only worse if you don't care about 50dBA of fan noise from your Tsunami. It was one of the loudest cases EVER reviewed by Anandtech http://images.anandtech.com/graphs/thermaltake tsunami dream_09080490953/4419.png
All have clean, classic looks. Lian-Li has removable drive cages whereas CM doesn't. Don't think you can go wrong with any of 'em.zA.Gosu said:I have narrowed it down to 3 cases. Lian-Li PC-61 or -60, and the CM Praetorian. They both seem great. Is there anyone who has experienced both and can comment on them?
I WILL be replacing the fans with some good 80mm fans. Which ones?
I have the Praetorian, great case. Many people who I have heard who have had both say the Praetorian has better build quality than Lian Li. They are both great cases, and IMO I find the Praetorian a much nicer case. I hate stamped fan grillszA.Gosu said:I have narrowed it down to 3 cases. Lian-Li PC-61 or -60, and the CM Praetorian. They both seem great. Is there anyone who has experienced both and can comment on them?
ShaolinDragon said:I have the Praetorian, great case. Many people who I have heard who have had both say the Praetorian has better build quality than Lian Li. They are both great cases, and IMO I find the Praetorian a much nicer case. I hate stamped fan grills.
If the only thing putting you off a Praetorian is the grill, I can tell you that I hated it too, but in real life it is beautiful, completey flush with the case.
EDIT:Good luck finding one thoughI cant find anymore for my mate in the UK, but you might have better luck in USA.
