Best card for a 300w system.
MetalSluggX
Hello I'm running a Dell :cool: Dimension 4700 with a p4@2.8, 1.5g DDR2 and a 300watt, oh yea and I've been using an X300 for the past year! :eek: I really don't want to spend any more money into this computer but I do need a video card upgrade.
What would be the fastest best valued card?
Oh yes It's PCI-E
Is that GTS worth the extra 65% price over the GT? How do they both compare to the x1950pro / 79x?
Forget the wattage on your PSU. What is going to matter the most is the AMPs on the +12V rail of your PSU. It should be printed somewhere on it. You may be able to run the X1950 pro if the PSU is decent enough. You'll have to consult the ATI recommendations to be certain and they will error on the conservative side. As for the Sunbeam 580W PSU, it's capability is overestimated by at least 280 watts. I think your OEM PSU will be just as good as that one. If you want a quality PSU with an actual capability rating, you'll have to pay accordingly. Think Corsair, Seasonic, or Fortron for example. Manufacturers try to hook us with wattage ratings on their cheap PSUs.
ATI/AMD say 450 watts for all their video cards... I hear some people run some x1950 pros on some 300watt power supplies, would this 512 work?
It will really come down how many devices you have drawing from the +12V source. I think the best answer would be to upgrade the PSU to the 400-450W range from a reputable manufacturer. You don't want to damage anything else due to a PSU failure. Also keep in mind that the power draw requirements for the GTS8600 will be about the same as the the X1950 pro. He's a link to help you out.
http://www.jonnyguru.com/
It depends. How much amps are there on the +12V rail of your power supply? If you can, try to take a picture of the side of the PSU with the voltage and Amperage numbers.
EDIT: Forget it, I found the info myself. Apparently that Dell PSU, if the documentation is correct, has 22A on the +12V rails. You can barely fit in a 8600GTS as long you don't have more than one hard drive or CD drive. Maybe an 8800GT but I think that's just asking for trouble.
Though I really do recommend getting a new PSU. That Dell PSU may not be able to handle the juice needed by a newer video card. And frankly, you don't want to risk that PSU dying out and killing your parts right? Any of these PSUs are substantially better than the current Dell PSU:
Antec Earthwatts EA380 380W PSU - $50
XCLIO Stablepower 460W PSU - $50
XCLIO Goodpower 500W PSU - $60
Antec Earthwatts 500W PSU - $60
Enhance ENP-5150GH 500W PSU - $68
And for the interested, here's the minimum amps a PSU needs have to power certain video cards (From eVGA's website):
8800 Ultra: 34A
8800GTX: 28A
8800GT: 22A
8800GTS: 26A
8600GTS: 22A
8600GT: 22A
7900GS: 20A
7600GT: 18A
For 25$ I guess I could get a 580W PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817709012
Does anyone know of any restrictions/issues when upgrading a Dell.
I've no idea if the pinouts for the PSU are the same as they were at one point or not--
The connector would fit as it would on any board; The problem was that it was wired differently. Stick a standard ATX PSU into it = dead computer.
The same was true for trying to put that same Dell PSU into an ordinary computer.
As I said, I don't know if that's still the case or not.
In any event, however, most big OEM companies like Dell are well known for putting in PSU's that are not especially beefy-Mostly with the notion, "The average consumer probably won't even crack the case open 8 times out of 10."
Unless Dell has changed, I dont think putting in a new PSU works, the computer won't boot (seriously, or at least this is what happened back in the day). Anyway, there's no point and telling him to go out and buy a brand new high-end video card when the rest of the computer cannot compete. MetalSlugg, what are you wanting to do with your computer that you need a new video card? It helps giving suggestions if we know a goal :).
dell psu are not standard so check this site for your dell pc,
http://www.pcpower.com/products/power_supplies/selector/dell.htm
you will find this one
There is some good news here. Dell has always been known for putting quality, yet proprietary parts in their systems. And their PSUs are no exception. IOW, that PSU may do the job just fine. And the worst that can happen is you try a new card, it doesn't work and you THEN buy a PSU with the right rails for the job. That is, if the guy above is wrong about PSUs not working in DELL made systems.
On the other hand, PC Power and Cooling makes Dell compatible PSU's. They're a little more expensive but very worth it. GL. http://www.pcpower.com/products/power_supplies/dell/
Edit: Just read the last suggestions--props to them for some good info.
btw, imageshack is the prefered method for posting pics :)
