best C2D for OC'ing still E6300?
THRESHIN
going to be building a new box for the wife soon, and she's taken a real liking to my opty 165. in fact, she wants to learn the dark side (a.k.a. overclocking). so planning a nice 'best bang for your buck' C2D overclockers rig. is the E6300 still the best bet? whats a good mobo to use with it?
6300 is still good, but e4300 will allow you to OC with cheaper ram due to its 9 multipler, (the 6300's is 7)
If you want to get good ram, it will be ~300 bucks. The e4300 is cheaper than the 6300 and will allow you to get ~200 dollar ram.
For mobos, the Gigabyte DS3 is real good. For sli, the 680i's are very good.
If you have good ram, get the DS3 (you cant run it unlinked) otherwise get 680i with any ram (run it unlinked)
I say DS3 + e4300 + ~200 dollar ram.
EDIT: keep in mind the e6300';s seem to be clocking consistently slightly higher than the e4300s still. From what I read the e4300s get up to ~3 ghz while e6300 can make it to 3.5
yep I agree with buffbiff21 100% and frankly I never thought the 6300 was the best OCer, just the cheapest. Go 6400 if you got the cash or 4300 if you dont, its performace is hardly distinguishable from the 6300
( http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2903&p=6 )
If you look at my sig, I got the 6300 when they first came out and either my memory or MB (pretty sure its the MB) is holding me back some due to the high FSB I must use.
ditto on the PC6400 even the 555 stuff
